e-brake and no accel?
Old Dec 28, 2003
dirtySAMURAI's Avatar
I log in from time to time
I don't get it...When I have the ebrake up and I slam on both the gas and brake (I have auto, btw) the engine will only rev to about 3000rpm and then it cuts off the gas to the engine (rev limiter?). When I turn with the ebrake up the car will slow down and start to tilt forwards, almost as if I were slamming the regular brakes and ABS turned on by itself. When I touch the brakes when I'm executing this type of "maneuver" it feels like it's pulsing, but I only have the ebrake up.
What the freaky is going on??
Old Dec 30, 2003
IronFist's Avatar
Re: e-brake and no accel?
Not that it answers your question or anything, but why are you doing that?
Old Dec 30, 2003
If I don't use all three, then I'll be moving forward. Let's just say that I'm trying to properly launch an a/t...
Old Dec 30, 2003
HondaLuver's Avatar
Its a celebration bitches!
the proper way to launch a auto is to go and get a manual, u are just killing ur torque converter and transmition, don't do it, it is very bad. and the reason it only goes to 3000 is because of the set stall speed... so people like u don't mess up ur transmitions
Old Dec 30, 2003
I'm thinking about it (conversion), but I think I'll save up for a new car instead of wasting my money on an auto to manual conversion for the family car. My sisters need to drive it too, and I don't think they'll be too happy with a stick shift.
Old Dec 30, 2003
modoman's Avatar
that story made me cringe
Old Jan 1, 2004
IronFist's Avatar
Dude so you are brake torqing (aka powerbraking)? You don't need the handbrake for that. It goes like this. Press the brake. Push the gas. Let go of brake. Launch. But don't do it too much. How high of rpms are you trying to launch from, anyway?
Old Jan 1, 2004
modoman's Avatar
i thought powerbraking was for rwd cars... so that the front brakes are are applied with just enough to force to keep the car still, while the rears smoke
Old Jan 1, 2004
tfnaaf's Avatar
BLDNPSI Mod
Torqing the motor up with the brake on to 3000 rpm approx is normal thats what is designed to do. As for ruining your transmision and or converter I would seriously doubt that unless you sat there torqing it for a long period of time. What it does do by torqing it up is it increases the tempature of the fluid and over time yes that could cause damage. Anything in excess is bad usually I regularly launch Auto Trans in the 2800-3000 RPM and have had no transmision issues. I do suggest that if you do this ALOT, then buy an aftermarket trans cooler.
This is because the ABS can see the difference in wheel speed from front to rear. and when you touch the brake pedal the computer is assuming that you are in a skid of some sort and starts to accuate the ABS 'pulsing of the pedal' . From what your desribing it sounds normal.
JohnnyBxo
Nov 12, 2015 03:04 PM
blward6
Sep 16, 2015 05:32 PM
SatansEnemy
Mar 30, 2003 10:41 AM
impetigo
Oct 23, 2002 02:48 PM
Silver2k1Dood
Jul 8, 2002 03:31 AM
