damn camber
Old Oct 9, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
damn camber
i dropped 1.4" and now rear tires r showing about 1/32nd less tread on inside compared to outside. not bad at all tires look brand new just like a 32nd difference if i buy camber kit shuld i adjust so they are plumb to ground or shold i kick them out 5-6degrees at the top to counter the affect until tread wear is even and then plumb them out...
riley
Old Oct 9, 2003
robbclark1's Avatar
Retired suspension supermod.
Hahaha. I would not put them to positive camber but you can. it wont help your handling to have them positive, and it might hurt handling. You also might rub the fender well. you just should have bought when you lowered.
Old Oct 9, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
i dotn care about handling i drive my car like 20 miles a day i was just gonna try and "level" off the tire and then reput back after the wear is normal.
Old Oct 9, 2003
robbclark1's Avatar
you will also look funny. And you should care about the handling because if you do something that negatively effects handling then you might end up in some serious trouble. I think you should have spent the money in the first place to ge a camber kit, but that is neither here nor there.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
