bad vibration... help
Old Sep 18, 2003
MattC1's Avatar
MattC1 is an unknown quantity at this point
I just put on a set of 15" rota C8's with 195/55/15 rubber... I never had any tuner lugs so I used my stock bolts and stock wheel lock the wheel is on very tight.. but at 55mph and up I get a bad vibration coming from the wheels... anyone with rota C8's did you use hub-centric rings? or could it be my stock wheel locks throwing the tire out of balance, those wheel locks are pretty big. also could it be that I am using stock bolts instead of tuner lugs??
thanks for the help
Old Sep 18, 2003
MadWheel's Avatar
Premium Boosted Member
Loosen all the lugs and tro to see the space around each of them. If you have they same problem I used to, the wholes on the hub of the wheel are bigger than the studs coming out of your car, you basically have to align the hub, keeping the space around each lug equal. This fixed my problem, hasen't given me a hard time since.
Old Sep 18, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Get new lugnuts. You cant use a ball nose lugnut in a conical taper. You put all the force on 1 little ring and you'll destroy the wheels.
When you get new nuts, get centering rings. You don't need them if you can accurately torque the bolts down, they will stay in place.
Old Sep 18, 2003
MattC1's Avatar
I will try what both you guys said. anyone else have any ideas?
Old Sep 18, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Take off wheel locks and put stock lugs back on. I had the same problem and couldn't figure out what the hell was wrong after 5 tire balances at 3 different shops. Finally took off my wheel locks one day for the heck of it, and problem was solved.
Old Sep 19, 2003
MattC1's Avatar
I did everything and it still vibrates, have tuner lugs installed and I still have massive vibration at high speed maybe ny tires weren't balanced
Old Sep 19, 2003
Ronin's Avatar
You mean you didn't go get them re-balanced yet?
Damn, that's the first thing you should have done... I thought you were having this vibration after you had them re-balanced already.
Old Sep 19, 2003
MattC1's Avatar
yes I bought them new and they were balanced.. what I am saying is maybe I should go back because they were not balanced right.
Old Sep 19, 2003
Ronin's Avatar
Yeah, that's I meant dude ... go back a 2nd time. Crappy balancing jobs are a common occurrence.
If your steering wheel starts shaking after any kind of balancing job, take it back to the same place and bitch about it.
Lots of times, I've had to go back more than once cuz of crappy balancing jobs on their first try. Seems like they only take the time to do it properly the 2nd time after I complain.
Old Sep 21, 2003
whitensimple's Avatar
whitensimple is an unknown quantity at this point
I've watched some places simply throw the wheel and tire on the ground and do a "Ground Centripical Force" balance.. just threw some weights on it. (pep boys lol) Typically when you get vibes at a certain MPH then it's out of balance.. quit spending money on different lugs. Hub rings are also for people with a glass butt, which is the last stretch a person will go to rid of the vibrations people feel with larger wheels and narrower tires.
SimpleUser
Apr 24, 2021 02:54 AM
Green02civic
Jul 27, 2015 10:48 PM
cukaracha
30
Jul 26, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
