When Did You Change Your Brakepads?
i'm at 54,000km and still using the same pads from day one. i just want to know what is the average before needing replacement on these pads. i'm driving a 02 civic si/ex. my breaks still work fine, but it does make a sound once when i break after breaking from the opposite directions. just want to know if its almost time to change. thanks.
Autocross Junky
I have 58000+ miles on my original pads too, and I autocross!!!! Gonna change them soon when I go to a higher temp break fluid....
Okay. I just replaced my pads with EBC GreenStuffs this weekend. I had ~25,500 miles on my car. The pad on the driver side was fine, but the one on the passenger side was really low. So low that it was hitting the squeal tab. If you take a look at your pads, you'll see on the inside pad that it has a little metal piece sticking out. This is the squeal tab. What happens is that when the pad is gone that little thing starts rubbing on the back side of your rotor, making a noise. That squealing is to let you know it's time to replace your pads. As far as when to replace your pads, it's all up to you and how you drive your car. Most cars that are daily drivers that don't see a lot of highway miles because they're driven in the city will probably be replacing their pads between 25,000 and 30,000 mi. Also, you may want to resurface your rotors at that time. You can only get them resurfaced twice, *maybe* 3 times if your lucky. Honda specs say not to take the rotors any lower than 19mm and they come at 21mm. If you have any more questions, just go ahead and ask.
Its a celebration bitches!
i changed my pads at 17,500 and 34,000, and im thinking of getting upgraded brakes when i need some new pads probly at 50k.
i don't know about my rear brake pads... how often are we suppost to replace our rear disc pads...
I just changed mine at 26k to upgrade my breaks to Brembo. They were really, really thick still. I couldn't believe how little the breaks had worn. In my RX-7 they were completely worn by 20k miles. I saved them just in case.
Originally posted by PrYnCeQT
also how do you know yourself that the brake pads need replacing?
If your brakes squeal then you're running low on pads or have run out. Replace them immediately if it comes to that. The squealing is a sign that the metal part of the pad is scraping the surface of your disc which isn't good at all.. If it scrapes too much you'll ruin the disc and will need to either get it resurfaced or replaced depending on the damage done.
And if you haven't noticed, everyone's pads wears differently. If you ride your brakes or do a lot of hard braking they may be done by 25k miles. If you do a lot of freeway driving you probably have more pad than someone who drives mostly in the city or some who brakes hard/often at high speeds (think over 100MPH).
I changed mine at 80,000km or 50,0000miles. Put in some performance pads and brembo slots. Honda mentioned to me that if you have heavier and bigger rims, it's a possibility that they'll wear out quicker.
7thgen Power Maker
If anyone is in need of New Rotors and pads. We have a GB here on the site for them.
http://www.7thgencivic.com/forums/sh...51#post1354351
I changed mine yesterday at 36,ooo miles
did a DIY
http://members.fortunecity.com/4jacks/brakes.html
If you look at picture #1 all the pads have a groove in the middle.
When that groove is gone , change your pads !
did a DIY
BootyDo
May 7, 2015 04:46 PM
andjosaus
Apr 28, 2015 10:02 PM
