Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Downsizing winter tires, staying within 3% diameter
Old Oct 7, 2024
jt-civic's Avatar
jt-civic is an unknown quantity at this point
Hi all,
I have a 2022 civic hatchback sport with the stock 235/40R18 tires. For downsizing, the Honda dealership (and a tire store or two) have recommended a 215/55R16 (0.4% smaller diameter) and some have also said a 205/60R16 (1.2% larger diameter) is fine.
I've been using this tire calculator here to compare tires and diameters: Tire Size Calculator
For the winter I'd like to use some winter tires and rims that I have from another recently sold car. They are 205/55R16 which is a touch different than the recommended tires. The 205/55R16 are 2% smaller in diameter than the stock tires.
My understanding is that anything within around 3% or so of the stock diameter should be OK. Obviously the speedometer will be a little off, but I'm wondering about traction control or any other safety systems (or causing some sort of "strain" on drivetrain or suspension components).
The bolt pattern, offset and hub bore size all fit fine (and I tried putting one of these wheels/tires on the car already and it fits well). So this is purely about the size of the tires (205/55R16 vs the recommended sizes above).
Any advice appreciated. I'm finding the dealerships and tire shops just want to say "The recommended size is X, we'd suggest you go with that.".
Old Oct 7, 2024
BrotatoChip's Avatar
Super Moderator
Re: Downsizing winter tires, staying within 3% diameter
If all four wheels are the same, there shouldn't be an issue.
Old Oct 8, 2024
GolNat's Avatar
Prelude Owner
they have to tell you that so they are not liable for selling you the “wrong” size. If they are all the same size I don't see an issue with 3% smaller.
Order tires online. Tire rack will make you verify with a check mark that the tires are a different size then manufacture recommended but you can buy them.
Old Oct 8, 2024
in winter, you want smooth. When making tires diameter smaller, you are doing the same as using a bigger final drive gearing. I would rather go with slightly bigger diameter than a smaller one for winter tires.
Old Oct 27, 2025
widude's Avatar
widude is an unknown quantity at this point
I use that tire size calculator at times also. For Winter I’d want to lean a little narrower footprint, on the pavement. I often look to get taller tires, for general use, have done so for my truck.
If I feel the shop may grouse at my ideas, I do the carry in thing. That means I take the wheels off and take them in a different vehicle. That way nothing to fuss about.
Bimtucklez
Wheels and Tires
Oct 25, 2021 06:31 PM
civichonda2002
Wheels and Tires
Feb 22, 2016 11:33 PM
YUL
Oct 15, 2004 06:11 AM
civicex01
Nov 24, 2003 07:32 PM
neoretromax
Aug 29, 2002 02:25 AM
