Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
Few questions for newbie
Old Mar 5, 2022
Icculus's Avatar
Icculus is an unknown quantity at this point
Hey y’all. With gas prices what they are I’m gonna have to park my diesel for a bit.
found a decent 2009 civic hybrid. Seller says the IMA light is on. I know this means it needs a new hybrid battery.
my question is, if this is on, other than replacement, can this mean anything else?
if it’s been on for quite some time can it cause damage if car was continually used?
Can that code be cause for another issue? Or is it specifically for the hybrid battery?
im not worried about buying a new one and switching it out. That’s easy. Just want to know what other variables I may be getting into.
Old Mar 5, 2022
Colin42's Avatar
Re: Few questions for newbie
Not something I would recommend doing unless you have experience working on hybrids
Old Mar 5, 2022
from reading other threads about hybrids, the normal battery going out can make the IMA battery to come up, although 2009 is past the normal life for IMA batteries.
the IMA light have codes to them too, but regular cheap scanners cannot read them, you will need to find a scanner that can read honda IMA codes (didn't search for them, not sure if they exist) and them find out what code is triggering the light
many parts compose the hybrid system, could be any of them, from charging to wiring to fuses, you would need to chase them
you can try to see if you can download a manual from here
https://www.scribd.com/document/2717...redid=&irgwc=1
there are cases were the light can come up when the battery gets exhausted and light does not reset automatically until a battery disconnected too
vangelis
Apr 1, 2025 12:32 AM
mohsin12
Dec 17, 2020 06:51 AM
propositionjoe
Dec 4, 2018 11:04 AM
propositionjoe
May 1, 2018 07:38 PM
