Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
Question on AC Compressor
Old Aug 9, 2021
Milopup04's Avatar
Milopup04 is an unknown quantity at this point
Hi All,
Seems I am in need of a new AC compressor for my 2014 Hybrid Civic.A couple of questions for the folks here.
Question: Is replacing the AC compressor more labor intensive (costly) on a hybrid Civic than replacing the AC compressor on a non-hybrid Civic?
Question: How much should I expect to pay to have the AC compressor replaced on my hybrid Civic? I am in Iowa. From casually looking for parts online, it looks like a new compressor is around $250. So I assume labor is the majority of the cost. I was quoted by one shop at $2300 for replacing the compressor alone.
Thanks in advance!
Old Aug 24, 2021
Asianflava's Avatar
Asianflava is an unknown quantity at this point
Re: Question on AC Compressor
Currently having issues with my 2012 Hybrid Civic compressor as well. I think my issue is the clutch it's noisy, but it still works. In my research I've found that this compressor is EXPENSIVE! Mainly because it is also a hybrid. It runs off the engine belt when the engine is running and has an electric motor to keep the compressor running when the engine is stopped. The $2300 part quote sounds correct, which is why I'm trying to just replace the clutch. The labor should be close to the same as a regular compressor. Came here looking to see if previous generation parts will fit.
Makadesoye
Interior
Jan 10, 2019 07:59 AM
simons81
29
Jun 20, 2015 08:33 PM
DBASRA99
May 2, 2014 11:51 PM
Mackln308
Mar 26, 2011 06:01 AM
Dark2k1
Sep 7, 2005 11:21 AM
