Customize your car Post here for any custom modifications you want to to to your car!
01 honda civic swap
Old Jun 3, 2020
Max42022's Avatar
Max42022 is an unknown quantity at this point
01 honda civic swap
Hi my name is zach I have a 01 honda civic and I was wondering if anyone knows what acura might have interchangeable interior parts? Doing a acura swap on it and wasnt sure wat parts I can use
Old Jun 3, 2020
FRSam's Avatar
Click Here
Re: 01 honda civic swap
What do you mean by "Acura Swap"?
https://www.civicforums.com/forums/1...civic-em2.html
https://www.civicforums.com/forums/1...seat-swap.html
Old Jun 3, 2020
Max42022's Avatar
I'm trying to do all acura seats and whatever else I can change eventually I'm doing a engine swap but wanting to know what seats and what ever other interior parts are interchangeable
Old Jun 3, 2020
FRSam's Avatar
Click Here
You know the best, easiest and cheapest way to get an Acura interior and a better engine?
Buy an Acura.
Old Jun 3, 2020
Moved to correct subforum
RSX front seats match 3 of the 4 mounting holes. IIRC, the 4th mounting hole just needs to be drilled out a bit. It's off by.. half or quarter inch? Rears fit into the coupe, but require cutting and some DIY upholstery work.
Shift assembly is the same. You won't gain anything from swapping in an RSX shift assembly. That said, any aftermarket one made for the RSX works
Here's a thread for all the suspension compatibility between the ES1/EM2 (01-05 Civic sedan/coupe), EP3 (02-05 Civic Si hatch), and DC5 (Acura RSX). Just noticed there's no mention of the rear sway bar. The 19mm RSX rear sway bar is a direct bolt in. Aftermarket endlinks recommended.
If you have access to Acura 1.7EL (Canada market), rear disc swap is direct bolt in. It's the USDM civic with Acura badging and a facelift. Alternatively, 2002 EP3 rear discs are a direct bolt in with no lug pattern change. The e-brake cable is too short though. RSX e-brake cables require some finagling to fit, but they fit. I had to open up the mounting brackets to take up any slack in the line to get them to reach.
I've seen people retrofit the RSX gauge cluster into the ES1/EM2. Leaves a gap at the bottom though, so you'd have to get creative with it or live with the gap.
Engine swap, you kinda mentioned. The K20A3/A2/A (RSX base or EP3/RSX-S/RSX-R, respectively) have been the swap of choice for 7thgen owners
There's prolly a lot more I'm missing, but those are the big ones
Mrg52210
Engine Swaps
Dec 12, 2015 02:57 PM
edrulz2003
Engine Swaps
Jan 13, 2007 11:00 PM
keviNxL
Engine Swaps
Jun 1, 2004 07:54 PM
briang
Oct 31, 2002 03:24 PM
TehBandicoot
Jul 31, 2002 04:46 PM
