Customize your car Post here for any custom modifications you want to to to your car!
Installing Lightbar on 2012 civic
Old Dec 10, 2025
AnderDingus's Avatar
AnderDingus is an unknown quantity at this point
Question Installing Lightbar on 2012 civic
Hey all,
I'm installing a Lightfox lightbar on my 2012 Si hatch and could use some guidance - the following links are for the lightbar and the wiring harness (https://www.lightfox.com.au/products...ing-wiring-kit), (https://www.4x4downunder.com.au/prod...guljKBmU51aJOv)
I was hoping for some guidance with the following in particular;
  • Wiring grommets: The lightbar switch needs to go to the driver's side (RHS), but I'm struggling to find a suitable grommet in the firewall to run the cable through (the 2 main grommets I can see are pretty full and can't fit my cable). Has anyone got any tips for this on an 8th gen? Where did you route it?
  • High Beam piggyback wire location: The harness is designed to piggyback off a high beam bulb connector, but the included cable is pretty short. This means I can only realistically tap into the LHS headlight, which has limited space and awkward access because of the battery. I'm considering extending the wiring with solder/heat shrink so I can tap the RHS headlight instead where there's better clearance. Does this sound reasonable, or is there a better approach?
  • Extra accessory wire placement: The harness has two separate DT connectors (may want to add spotlights later). Any suggestions on where to mount these so they're accessible but out of the way? Is coiling it up and putting it up the back LHS reasonable - open to any suggestions.
Haven't done a lot of stuff like this etc. so appreciate any help
Cheers,
Ander Dingus
Xbrittany1x
Electronics
Nov 19, 2020 07:48 AM
Stocksi12
Apr 17, 2014 05:19 AM
sratrainer
May 7, 2012 08:35 AM
bladebarrier
Feb 22, 2009 11:16 PM
heyitziak
Lighting
25
Nov 18, 2006 11:02 AM
