Firewall Location : 0/1 Gauge Civic 2004
Old Jan 2, 2009
bladebarrier's Avatar
bladebarrier is an unknown quantity at this point
I read the info here regarding the firewall location that most people use for their civic power wire, but it doesn't appear that it will work for me.
I found the firewall plug just fine, but I seem to have a large wiring harness that's already taking up most of the space. Is there a secondary location that is similarly sized?
Here are pictures of what I spotted, and a comparison of the wire I need to run through it. As you can see, the harness that's already there is about the same size as the aught gauge wire I need to run, so any location that is similar to the occupied spot, should be ok.
Sorry for the image quality. I hope it gives a reasonable view.
Old Jan 3, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Firewall Location : 0/1 Gauge Civic 2004
It should fit alright. Just chop off part of one of those black pieces that is attached to the harness and punch a second hole in the grommet. Or you can detach the harness completely run the wire and reattach all of it back to the grommet.
Old Jan 3, 2009
There just doesn't seem to be enough room going through the actual wall. I can't even push my finger through the hole, because the seal is so tight, with that harness taking up most of the space.
Old Jan 3, 2009
electric130's Avatar
i cut my rubber grommet beside the harness to push my wire through. i got a 4ga cable through easily.
Old Jan 3, 2009
Gotcha. I'll cut away some more and try again.
Old Jan 3, 2009
i drilled another hole in the spot where it looks like there should be one. i have alot of other wires tho so the factory one wouldnt work.
Old Jan 3, 2009
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Yeah drilling is the key with larger wire size like that.
Old Jan 3, 2009
Was that where the circle is drawn on the insulation, in the shots I took?
Old Jan 3, 2009
I got through the factory grommet. What a pain though.
If I had to do it again, I would have just drilled a new spot.
It took a lot of careful cutting to avoid damaging the tiny wires that were bundled in the area, and I had to puncture the grommet all the way through with an awl spike, and then stretch it, to avoid ripping the insulation off of the existing wire bundle while feeding the zero gauge through.
The factory hole is big enough, but the rubber seal that you have to go through, on the engine compartment side, is extremely tight. If it weren't for the wires that were already in place, it would have been cake.
Old Jan 3, 2009
speedfoos's Avatar
There is another hole right above the gas pedal that your heater actuator cable (it's blue) goes through. That hole - once you pop the little grommet out - is more than big enough for a piece of zero gauge.
Old Jan 4, 2009
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
im going to run mine under the car along the nitrous line
Old Jan 5, 2009
WannaBFast's Avatar
Prowlin' with a Purpose
its so the people with the velcro and stapler can know where to staple the velcro to hold the carpet down
Old Jan 5, 2009
It must have been one of the Hondas made in America then.
Old Jan 16, 2009
ClickRight's Avatar
ClickRight is an unknown quantity at this point
Geeze, how did you get that grommet out? I tried from in the engine bay, but that baby was going nowhere. I found a rubber stopper under the gas pedal, hoping that I could get some wire through, but it just lead to nothing (and it's a bit too low for my liking) Please tell me how you got the actuator grommet out
Old Feb 22, 2009
ClickRight's Avatar
Anyone, please?
It's making me that I can't figure this out.
tylerginevan
Apr 27, 2015 12:29 PM
chgofirefighter
Apr 18, 2015 08:08 PM
GH04si
Apr 15, 2015 08:13 PM
meels808
Nov 9, 2001 03:08 PM
fordfocussucks
Nov 6, 2001 03:16 PM
