Finally started my retrofit project *UPDATED AGAIN HELP NEEDED*
Old Sep 21, 2006
heyitziak's Avatar
suffering the heat in my black civic
heyitziak is on a distinguished road
After hours and hours of soldering, heatshrinking, taping, crimping, and wiring, i finally finish my first wire harness from scratch. woot *pad on the back*. Also mod my ballast with male disconnect.
My first wire harness, now just need to wait til the morning to test it out.
Denso Ballast with male disconnect, easiest part of the work i did today. all i did was cut, strip, crimp, tape, heatshrink, and more tape.
This is what happen, when a noob try to solder.
don't know if you can see, but the flat side(what i started with) is not like a hole full with soldering wire.
Update tommorow when i take out my headlight, rip it apart, and try to fit everything together. also doing an angel eye DIY, don't know how everything is going to turn out.
Wake up this morning, took out the front bumper, and took out both of my headlight. also hook up my wire harness to battery and test out my projector. and it works!!! here is some pictures
tyc projector
all bulbs out and ready to be baked and tear apart.
AHHHH! i am stuck at aiming. i don't know how i am going to aim it. any idea on how to aim a valeo in tyc? or how to proper mount it as well. the projector is mounted by the 2 bottom adjuster bolts. and no matter how i try, it just now going down. i am driving with low beam that look like high beam. HELP IS NEEDED
Old Sep 21, 2006
jay78's Avatar
jay78 is on a distinguished road
nice so u finally made the harness....
Old Sep 21, 2006
heyitziak's Avatar
yea took me a while, btw i need some serious help on shield bending, mine cutoff line is like all weird
Old Sep 21, 2006
jay78's Avatar
pm replyed...
Old Sep 21, 2006
PunkingCivic's Avatar
I need TP for my bunghole
nice. keep them pix coming
Old Sep 21, 2006
have fun! take time. i need to open mine again sometime and fix the projector in better, and seal em up.
Old Sep 21, 2006
jay78's Avatar
this time tie your projector from top and bottom so they dont shake and then aim them perfactly then seal the back
Old Sep 21, 2006
heyitziak's Avatar
i update my first post, please read the bottom paragraph, i need help now, i cant drive around with high beam, help please
Old Sep 22, 2006
jay78's Avatar
ok so u put the projector on the two tyc bolts then did u put nuts one front of the projector and one behind(two nuts for each bolt)??? if u did then it should move the projector up and down....unscrew it will make the projector go down and screwing it will make the projector go up,
,.....other should make the projector going left and right.....
Old Sep 22, 2006
heyitziak's Avatar
o ok, so wt nuts should i use, as in what size? #6?
Old Sep 22, 2006
jay78's Avatar
for tyc u need 5mm 8 u gone need 8 of these u can get them at homedepot... $1.59 2nuts in each bag so total 4bags u need to buy
Old Sep 22, 2006
heyitziak's Avatar
thanks i am gonna go buy some 5mm nots now
Old Sep 22, 2006
jay78's Avatar
make sure its 5mm .8
Old Oct 29, 2006
heyitziak's Avatar
where can i buy 5mm .8 online? i cannot find any around the hardware store around my place
Old Oct 30, 2006
jay78's Avatar
so how did u do your bi-xenon wiring... whre did u connet the high beam wire... black and red wire.... let me know wich # on relay
thankx
Old Oct 30, 2006
heyitziak's Avatar
i use 87 on the second relay to wire to the high beams. bump still need help on where to buy 5mm .8 nuts online thanks
Old Oct 30, 2006
jay78's Avatar
i dont know where can u get them..... i bought mine from HomeDepot
well on relay where did u connect your hi-beam from stock harness on relay?
Old Oct 30, 2006
heyitziak's Avatar
i made a connection from 87 on high beam relay, and modify the high beam on tyc with a connector and just simple plug and play.
bump still need help on where to buy the 5mm .8 nuts online, none at my homedepot very ghetto
Old Oct 31, 2006
jay78's Avatar
tell me how did u connect #85 and 86 on relay.....
here is the part number that u can order from home depot
here is the pic
Old Nov 13, 2006
heyitziak's Avatar
i got the 5mm nuts and finally tie them down, but now i still don't know how to tie them so they aim down a lot more. right now the cutoff is at exactly where my high beam is. Will bending the shield help? or i need to know how to aim the projector down, because no matter how i do it its still aimming at the same place as without the nuts. help needed thanks
Old Nov 13, 2006
jay78's Avatar
are u putting one nut front of projector and 2nd one behind ?? so u need two nut for each screw... total 4 nuts each side/../
Old Nov 14, 2006
heyitziak's Avatar
yea thats wt i did, i got a total of 8 nuts, 4 on each side, 2 on each bolts, 1 under, 1 above the projector. i just don't know how to screw it in so the it acutally will force the projector to aim down. do i need to cut some parts off from the back or off the projector. cus the furthest i can go, the back of the projector seems to be force down by the tube part for the low beam (the tube like at the back of the headlight with rubber thingy to cover over it) should i cut some off cus the headlight cannot go down more when its restrict by that tube thing. any help will be good. please help, everything is done just stuck on the aimming part.
Old Nov 15, 2006
jay78's Avatar
so did u tight both nuts (front of projector and behind) goal is when u turn the screw from behind the housing make sure that nut is not turning with it if it does then your projector won't move its not gone do noting.... when it dont turn then u will see your projector moving.. good luck dude.
Old Nov 18, 2006
heyitziak's Avatar
yea it moving but its not going down. i dunno why. i need to find a way to make it lower
Old Nov 18, 2006
jay78's Avatar
look for gearbox he post the pic back of his headlight, you tie the back of the projector pulling up from back that should bring the front part down... let me seee if i can find his pic...
Old Nov 18, 2006
jay78's Avatar
here found it
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
jetcare101
May 8, 2015 01:33 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
black2k1vtec
Dec 6, 2001 09:49 PM
