Air Conditioning Post issues about air conditioning here
Is this what a Freon leak looks like?
Old Aug 4, 2025
bior37's Avatar
bior37 is an unknown quantity at this point
I'm tracking down a potential leak in my 2010 Honda Civic (which is causing intermittent compressor clutch shutdown). I recently had a brand new compressor put in, and the only place I've found some dye with a UV light is where the new compressor attaches - but I've never looked for leaks before and I can't tell if this is a serious leak or not. Maybe it's just leftover dripping from installation?
I also noticed that when I untwisted the caps on the H and L valves, they hissed like opening a soda. This would lead me to believe that my valve cores (which are stock) are leaking?
The leak could also be in the evaporator core, and I'm considering renting a sniffer to test that.
Old Aug 6, 2025
Colin42's Avatar
Re: Is this what a Freon leak looks like?
Try cleaning all of that off. See if fresh dye shows up
Definitely sounds like the valve cores are leaking.
Andym
Air Conditioning
Aug 7, 2023 07:21 PM
Toolian
Air Conditioning
Jul 9, 2021 07:06 PM
tommcd09
Air Conditioning
Mar 19, 2021 09:12 AM
cukaracha
30
Jul 26, 2015 12:01 PM
wpaxt
Apr 15, 2011 01:52 PM
