Air Conditioning Post issues about air conditioning here
8th gen A/C issue
Old Apr 2, 2023
Honda_G's Avatar
Honda_G is an unknown quantity at this point
8th gen A/C issue
Greetings. I replaced the compressor about 6 to 8 months ago. It started short cycling really bad then winter came and I didn't run it. I recently replaced the condenser, dryer, evaporator core, and expansion valve. I pulled a vacuum for hr fifteen minutes then it held a vacuum for an hr fifteen minutes. I added freon (acpro)
using there chart. Said I should have around 35 to 40 psi. Well once it got to around 30 it wouldn't take anymore which was very strange to me. I did add pag oil btw. At this point it wasn't short cycling and the vents were about 48f on the passenger and about 58 on the driver 🤔 I checked all three actuators and they are working. I went for a drive to discover what appeared to be a whining coming from the compressor. It's loud enough to raise concern so I shut it off and the noise immediately stopped. Even tho the compressor is pretty I'm thinking it's faulty. It was less then $200. I ran diagnostic on ac control panel and it passed. After everything that was done it should be ice cold. Any help is greatly appreciated. Thx
::EDIT:: this morning it is freezing as yesterday mid 80s wasnt. More cool then anything.
Old Apr 3, 2023
Colin42's Avatar
Re: 8th gen A/C issue
Crappy cheap compressor would be my guess
rogersracing89
Air Conditioning
Jul 8, 2020 12:12 PM
Mar 3, 2017 01:11 PM
JJ291
Sep 2, 2015 11:49 PM
adamdrives
15
Aug 8, 2015 08:53 PM
DamnYank
Mar 18, 2015 09:26 PM
