Air Conditioning Post issues about air conditioning here
2006 Civic AC Problem
Old Jul 20, 2022
Djkraiz's Avatar
Djkraiz is an unknown quantity at this point
[size=16px]I have a 2006 Civic EX 5speed and the ac compressor keeps cycling every 5-10 seconds. I have replaced everything from the condensor to the evap core, pulled vacuum, added PAG oil according to specs and added freon accord to specs and the ac compressor and both fans still keep cycling every 5-10 seconds. Even if the climate control is off, the compressor and rad fans still cycle every 5-10 seconds. Any input greatly appreciated.[/size]
[size=16px]Following AC components have been replaced:[/size]
[size=16px]New Compressor (replaced 3x)[/size]
[size=16px]New condensor and dryer[/size]
[size=16px]New evap coil[/size]
[size=16px]New expansion valve (replaced 2x)[/size]
[size=16px]New pressure switch[/size]
[size=16px]New high and low side pressure hoses[/size]
Old Jul 20, 2022
Colin42's Avatar
Re: 2006 Civic AC Problem
I know the compressors on this generation failed constantly.
Old Jul 20, 2022
Djkraiz's Avatar
Pretty much all ac components have been replaced with new components from the condensor all the way to the evap coil.
Old Jul 21, 2022
BrotatoChip's Avatar
Super Moderator
Cycling on/off is normal so the evaporator doesn't freeze up. It's not supposed to do that with the A/C off though. Are you having HVAC performance issues?
Old Jul 21, 2022
Colin42's Avatar
so did you replace it or not?
Old Jul 21, 2022
Djkraiz's Avatar
I don't think its suppose to cycle on and off like that, and it is not blowing cold at all. Doesn't give the compressor enough time to pump freon thru the system at all.
Old Jul 21, 2022
Djkraiz's Avatar
I went thru 3 different brand new compressors, don't think its defective.
Old Jul 21, 2022
Super Moderator
Could be the low pressure switch kicking it off. Use a set of manifold gauges to read low/high side pressure while the compressor is cycling.
Old Jul 21, 2022
Djkraiz's Avatar
Head pressure is good.....why would the fans and compressor constantly cycle every few seconds with the engine ar idle and climate control completely off.
Old Jul 21, 2022
Super Moderator
What pressures did you read?
Old Jul 21, 2022
Djkraiz's Avatar
As soon as I get readings from low and high side I'll post them.....Im trying to figure out why system keeps cycling when climate control is off. Bad readings shouldnt cause this....
Old Jul 22, 2022
Super Moderator
If you just have the A/C turned off it can still come on when in defrost mode. If you have the entire HVAC system turned off (no interior fan) then it should not be cycling.
If you're seeing the later, you'd have to start troubleshooting the compressor power circuit. It would be getting power from somewhere it shouldn't.
Old Jul 22, 2022
Djkraiz's Avatar
yea the entire system is havc system is off and no air is blowing in the cabin but as long as the engine is idling, the compressor amd fans keep cycling every 5 secs. Im leaning towards a faulty ecu.
deanh22a
Aug 18, 2017 07:55 PM
DamnYank
Mar 18, 2015 09:26 PM
abarri01
Jun 23, 2013 01:31 PM
jonprince
Jun 19, 2010 02:05 AM
AzNmiKex215
Apr 9, 2005 07:47 AM
