2009 Civic AC problems help!!
Ok, 09 Civic sedan compressor bearing seized causing serpentine belt to snap. I replaced the serpentine belt and purchased a brand new AC compressor. I had the system Professionally evac the system and charged and clutch will not engage. Changed the clutch relay still won't engage. Changed the low-pressure switch still won't engage. The only way the clutch comes on is if I jump the relay which I did use an electrical wire from relay location. I tested the low-pressure switch connection and got 5volts from the signal output as it said I should be getting. Please help I don't know what else it could be..
Kyle Gleason
Jul 20, 2017 12:07 AM
Roman Rembacz
Jul 16, 2015 12:30 PM
mdona91690
Jul 24, 2014 04:11 PM
BrotatoChip
19
Jun 28, 2012 05:11 PM
