bypassing the ac compressor????
Re: bypassing the ac compressor????
I do bypass the ac compressor of my Honda Civic 2010
For what reason was it bypassed?
my battery drain
Is it just a failing battery?
Did you electronically bypass the ac or remove it from the belt options?
Guessing you're running a shorter belt.
As long as you run every other option on the belt in the exact same direction it was originally in, you should be fine.
-check your belt diagram
-check the alternator tensioner
DanS
Jan 25, 2012 06:19 PM
