Air Conditioning Post issues about air conditioning here
2010 Honda Civic Hybrid A/C Trouble
Old Jun 12, 2018
CrazySk8er23's Avatar
CrazySk8er23 is an unknown quantity at this point
Hey guys,
I've been looking at a bunch of forums looking for a solution to my A/C problem but finally decided it would probably be best to just make a post myself.
I have a 2010 Honda Civic Hybrid with the 1.3L 4Cyl with about 131,000 miles on it. My A/C has been working fine and then it suddenly stopped working about 2 weeks ago. The A/C fan and the A/C clutch arm haven't engaged but then I noticed they both turned on for about 10 seconds right when I start my car before shutting off again. I've switched out the fuse under the hood with one of the other fuses that match its size and that didn't fix it, I bought a r134a refill can but when I connected it to the low pressure port and it read that it was full, a buddy of mine also has an 8th generation civic with working A/C so I took off his low pressure switch and put it on mine to test if that was the issue and that didn't fix it. I'm trying to test all that I can that could be a smaller fix before I go straight to replacing the compressor.
I'm not a mechanic but I am able to do some minor fixes myself. Are there any other things I should test before taking it to a shop to get a professional to look at it?
Thanks in advance!
Old Jun 12, 2018
Re: 2010 Honda Civic Hybrid A/C Trouble
10 seconds......
Does the inside fan work? If it doesn't work it will shut down the AC system.
Is the thermal protector going open circuit at 10 seconds? That would shut down the compressor and radiator fans too.
Old Jun 12, 2018
Both the fan and the clutch arm normally don't spin but I noticed today that when I started my car, they turned on before shutting back off for the rest of the drive.
I'm not sure how to check that if that would be the problem.
Old Jun 14, 2018
Wiring diagram and volt/ohm meter, and you'd have to be able to check it WHILE it's quit working.
Another huge complication is the fact it's a hybrid.
See the fat orange cables going to the AC compressor----- the compressor is dual drive meaning the IMA system can run it on the HV system.....that makes it dangerous AF for the average Joe to mess with stuff.
Got any IMA system fault codes?
Has someone messed with the AC system before you, maybe contaminated the special refrigerant oil in the system? Incorrect refrigerant oil won't have the necessary insulation properties and the IMA system could shut it down if it detects voltage leaking.
preach2u
Jul 10, 2022 09:31 PM
rugbynut
General 8th & 9th Gen
Aug 15, 2018 12:26 PM
mick1putt
Apr 15, 2017 01:23 PM
Picartman
Mar 1, 2016 11:19 PM
deaninsavannah
Sep 28, 2013 10:14 AM
