Air Conditioning Post Issues about Air Conditioning here
97 civic a/c issues
Old Jul 17, 2023
Reyvin9863's Avatar
Reyvin9863 is an unknown quantity at this point
97 civic a/c issues
I have a 97 civic ex. Last year ac working rediculously perfect. Parked one night and when i came out next morning ac not working. No warnings or trouble before just stopped. I checked underhood relays and all fuses...all good. I ended up having mechanic put in a new compressor as old one was frozen up. The problem is after installing compressor motor wouldnt kick in electrically unless it had a jumper. We changed out the control unit after retesting all relays & fuses again and still no change. I asked him to just add a direct switch to compressor so i dont fry which works but its not the way its supposed to work and i want to fix it...can u folks help...thanks in advance
Old Jul 18, 2023
BrotatoChip's Avatar
Super Moderator
Re: 97 civic a/c issues
Compressors don't just seize overnight without warning. I suspect there wasn't anything wrong with it. And a mechanic that cannot troubleshoot a fairly simple electrical system?? Get a new mechanic.
It could be any number of things:
-Failed compressor clutch
-Bad relay (that electrically tests okay)
-Damaged/cut wires
-Failed low pressure switch
-Failed HVAC controls
-Etc.
Old Jul 18, 2023
Colin42's Avatar
+1 new mechanic
alexkharden
Apr 23, 2015 07:13 PM
hotrod_714
May 17, 2014 04:50 PM
slikbike
Aug 27, 2011 10:17 PM
JrBK
Jul 28, 2011 10:50 AM
210italian
Mar 26, 2010 10:00 AM
