Air Conditioning Post Issues about Air Conditioning here
2000 AC not working clutch wont engage
Old Mar 28, 2021
iedwards23's Avatar
iedwards23 is an unknown quantity at this point
I'm trying to see if I have an issue with my AC clutch or another part of the system. The static pressures are not correct. When car is off I have 25 psi on low side and 110 psi on the high side. When you turn the car on and hit AC the compressor will not turn on. The AC in this care worked about a month ago.
Old Mar 28, 2021
Colin42's Avatar
Re: 2000 AC not working clutch wont engage
Need at least 40psi on the low side for the compressor to engage
Old Mar 28, 2021
iedwards23's Avatar
I though that as well so I was going to bypass the relay to try to fill but AC clutch still wont engage. Seems like the compressor is shot. I also feel like I may have a clog since static pressure is not the same on both the high and low when car off. I may just replace the system.
Tracecross30
Air Conditioning
19
Sep 22, 2020 04:07 PM
got2run5
Jul 28, 2017 07:14 PM
Red77
Mar 27, 2013 04:41 PM
bcledfoot
May 26, 2011 11:33 PM
JcivicW
Jun 2, 2010 02:22 PM
