Air Conditioning Post issues with air conditioning here
02 civic Ac issue
Old Jul 24, 2020
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
02 civic Ac issue
So after a few months from of installing an Ac condenser in my car and fill up with Freon, my Ac is not. Working until checked and see that the clutch is not engaging at all. I turned on the car and tapped the clutch several times but it still doesn't showing any signs of wanting to work. Could it be that the clutch is the problem since I'm sure that refrigerant in the system?
Old Jul 24, 2020
Colin42's Avatar
Re: 02 civic Ac issue
Did you check to make sure it hasn't all leaked back out?
Old Jul 24, 2020
No but i dont think its leaking though. If it leak out, would that cause the clutch from not engaging?
Old Jul 24, 2020
BrotatoChip's Avatar
Super Moderator
Yes...
If there is less than 28 psi the clutch will not engage.
Old Jul 24, 2020
Yes...
oh, ok.is there anyway to tell if its leaking without taking it to a shop for testing?
Old Jul 24, 2020
Colin42's Avatar
Buy a set of manifold gauges
Old Jul 24, 2020
Do both radiator fans still come on when you try to turn on the AC?
This is important information.
If they DO still come on when you turn on the AC, the system still has enough pressure to turn on the compressor.
Old Jul 25, 2020
yeah i think they do as i tried that before but,let me double check in the morning to make sure and get back to you.
Old Jul 25, 2020
so i turned on the Ac and checked the fans but they are not spinning at all. I watch them for a few minutes but they didn't came on..is there a way to check for leak in the system without taking it to a shop to have check?
Old Jul 26, 2020
Colin42's Avatar
Yes.
Old Jul 26, 2020
Yes.
ok. Watched a video on YouTube where this guy used the same freon with die in it and he put it in the system and afterwards,he used a uv light in the dark to chech for leaks. I might just have Orings that needed replacement. But i might just take it to shop because i dont have much place to put much tools.
Old Aug 16, 2020
There's other possible reasons besides lacking freon. It's still 50/50 chance of being an electrical or mechanical problem instead of a low freon problem.
If the pressure switch (located on the drier can) shows continuity (ohm meter test) , the system still has enough freon inside it to turn the compressor on.
Old Aug 17, 2020
the compressor not engaging at all. Because the AC compressor clutch not spinning,no Matter how i topped it.im taking it somewhere to have it check out.
Old Sep 21, 2020
so back to this Ac issue. I removed the compressor clutch condenser relay used a paper clip and put into the 87 and 30 hole and turn on the Ac and the compressor came on but the air wasn't cold..
Old Sep 22, 2020
Super Moderator
You still haven't checked pressure in the system, have you?
Old Sep 22, 2020
no i didn't because it was raining and it still is raining.. I just open the cap from the high and low pressure lines and pressed the tip on the inside to see if any freon in the lnes.but i know what i did couldn't determine the pressure. I think i have a leak. After i pulled the relay, i shake and listen for any shaking from the inside but there was non and i switch the relays to and it was the same with all of them so i think its leaking somewhere.
Old Sep 22, 2020
leok99's Avatar
leok99 is an unknown quantity at this point
You can rent the gauge from Autozone/OReilly.
Old Sep 22, 2020
ok..what pressure should i get when i connect the gauge to the lines and which line should i connect the gauge to anyway?
Old Sep 22, 2020
Colin42's Avatar
Go back and read the old replies to this thread, we've explained all this to you already
Old Sep 22, 2020
thank you very much..
got2run5
Jul 28, 2017 07:14 PM
cgrimond
Jun 10, 2011 08:46 AM
bcledfoot
May 26, 2011 11:33 PM
JcivicW
Jun 2, 2010 02:22 PM
