Air Conditioning Post Issues about Air Conditioning here
A/C Performance Issue
Old Jul 13, 2020
jimyoung111's Avatar
jimyoung111 is an unknown quantity at this point
My 96 civic a/c blows cold, but very low fan output. Have to run fan at 2, 3, or 4 to get meaningful flow. Tried to charge system and now I get hot air blowing. Condensor turns on, but the higher the fan setting, the warmer the air. I also get an intermittent pulsing from condensor. Sounds like it's under a heavy load, but not sure that's the right description. Any suggestions? Thank you.
Old Jul 13, 2020
BrotatoChip's Avatar
Super Moderator
Re: A/C Performance Issue
A/C charge has no effect on air flow output from the vents. I would look at the cabin air filter, it's probably dirty and blocking air flow.
The condensor doesn't turn on, I believe you mean compressor. So did you take a bottle and just put it in the system without measuring pressures at all? It's likely over-charged now.
Old Jul 13, 2020
Thank you. I will get a new cabin filter. If I overcharged the system, is there a way to fix that?
Old Jul 13, 2020
Super Moderator
Get a real set of gauges and verify it is overcharged first. Or have a shop recover and then recharge the system.
Old Jul 14, 2020
Last night I had a pro test my system and he used proper gauges to confirm that the pressure and charge is ok. The low pressure line was hot, which concerned him. Air blowing into car was warm. It eventually cooled off, but air coming out of vent is still not cold. My mechanic is investigating this further, but I'd appreciate any other ideas or things to check. I found out cabin filters were not yet available in my 96 Civic, but I'd still like to figure out what could be reducing air flow. Thank you.
Old Jul 14, 2020
Super Moderator
Did they say what pressures they were reading?
I wasn't sure if 6th gens had cabin filters. I tried searching an online parts store and they had some available so I assumed. There are a few other things that could reduce air flow: failing blower motor, failing fan controls, blockage in the ducts, maybe a bad blower motor resistor.
Old Jul 14, 2020
Colin42's Avatar
No cabins on 6th gens
Old Jul 15, 2020
Super Moderator
Dammit Autozone, you let me down again!
Old Jul 15, 2020
Colin42's Avatar
Based on the things I've heard about that place I wouldn't trust them to sell me washer fluid
em2maxamillian
May 3, 2012 10:28 PM
karms
Mar 26, 2010 01:18 PM
ex2k3
Sep 21, 2006 12:58 AM
tony_buttons
Aug 23, 2005 10:07 PM
thiscrackerntam
Oct 30, 2004 07:43 PM
