Air Conditioning Post Issues about Air Conditioning here
Need help with heating valve under the hood
Old Nov 29, 2019
Artemas Rex's Avatar
Artemas Rex is an unknown quantity at this point
The heating/cooling **** in my 2000 hx has never worked. There is no AC but for the most part I've been able to turn the heat on/off by going under the hood and fiddling with the **** that seems to be connected to a valve of some sort. I have no idea how it works, I've just had to stand there with one hand in the interior over a vent and the other messing with the ****.
Since the weather has just turned cold I haven't had any success getting the heat back on. At best I get tepid-warmish air. i wouldn't be surprised if I've somehow damaged the valve because I've turned it 360+ degrees several times. Along its axis it has 90 degrees of firmness, 90 degrees of looseness, then 90 firm and 90 loose. It'd be great to have an understanding of how this thing works so that maybe I can intelligently get the heat on, rather than just turning it this way and that until I (hopefully) get the setting I need.
Now, hopefully there are some people on here surfing on the Friday after Thanksgiving. Because tomorrow I need to drive from Oakland back to Salt Lake City with my dog in the back, and he's going to want that heat!
Old Nov 29, 2019
Re: Need help with heating valve under the hood
Can't tell you for sure since I don't have a cutaway view of the valve, but it's likely a butterfly or ball-**** valve (most likely the latter) that controls coolant flow into the heater core. If anything makes sense in the world (which, we all know, often times is not the case), if the "lever" is pointing along the pipe, then it should be open. If it's sticking out perpendicular to the pipe, should be closed.
This position tells me this should be a closed valve.
Old Nov 29, 2019
Okay, this makes sense. THANK YOU.
Old Nov 29, 2019
np my dude. That's what we're here for. I just hope that they designed that valve with some common sense in mind. That vertical pin is supposed to connect to something that controls it opening and closing from your instrument panel.
Jan 30, 2018 06:36 AM
Atarian
Oct 1, 2013 10:33 PM
Razgriz1500
Sep 15, 2012 11:29 PM
kentcams
Dec 27, 2008 01:54 PM
