Regular Maintenance Post Questions/Information about Regular Maintenance here
Is Wrong Oil Bad For Older Civics??
Old May 24, 2019
Hondaproblems's Avatar
Hondaproblems is an unknown quantity at this point
I recently got an old 2003 civic 1.6
I got it for dirt cheap and it just needs a little tlc
Anyway I noticed there was a 10w 40 can of oil in the boot that wasn't fully empty so this is more than likely in the engine.
According to the specified oil you should use it's 5w 20
I know thicker oil is good for high mileage old engines but this old car only has 119k miles.
Would ye change the oil or leave it alone?
Old May 24, 2019
Colin42's Avatar
Re: Is Wrong Oil Bad For Older Civics??
the seller may have put that in the engine to hide something, put the proper oil in it with a new filter and cross your fingers
Old May 25, 2019
Slumpertcivic's Avatar
Personally, I think high mileage oils are bad for oil rings, if the PO already kept a bottle of oil in the boot, you know they are already likely bad.
Common senario, oil light comes on, drive to nearest gas station and buy whatever oil they have.
Old May 25, 2019
mikey1's Avatar
change the oil and use 5W20
Old May 25, 2019
GolNat's Avatar
Prelude Owner
Yes change it and run 5w-20.
Old May 27, 2019
SlowboyZ's Avatar
SlowboyZ is an unknown quantity at this point
That's what I use. I have 220k miles and switched to 10w40 about 2 years ago.
Old May 27, 2019
Colin42's Avatar
in what car with what engine?
Old May 27, 2019
SlowboyZ's Avatar
05 civic ex. I change it every 3k-4K miles using conventional oil from chevron that I buy per case at Costco.
Old May 27, 2019
Colin42's Avatar
i would run the proper oil in that but its your car
Old May 28, 2019
mikey1's Avatar
why did you change from 5W20 ?
Old Jun 12, 2019
SlowboyZ's Avatar
Idk. I guess I felt it 5w20 was too thin for my high mileage engine. And where I live it's get hot in San Bernardino. A/c still blows cold though.
Old Jun 12, 2019
mac25's Avatar
Dr Krieger of Modification
No issues = 5w20 all temperatures
Burning due to piston rings = 5w30
Burning do to valve seals = 10w30
Leaking, depending on leak rate
-5w20 high milage
-5w30 h.m.
-10w30 h.m.
(Stop leaks can be used on combo with the options above)
Old Jun 16, 2019
I put in 5w 30 and a new filter and everything is still okay.
Old Jun 17, 2019
I don't know if there was something else, like a particle too big that passed through, but I had VTEC engagement issues when using a oil slightly too thick.
5hamers
Nov 13, 2016 01:04 PM
crypticlineage
Dec 30, 2012 02:20 PM
HwNpRyDe_CiViC
Oct 24, 2006 06:38 PM
S2000man01
Feb 16, 2005 09:28 PM
Dasica
Aug 12, 2003 10:53 PM
