Air Conditioning Post issues with air conditioning here
Temperature door blend actuator help 2003 civic
Old Jul 26, 2023
Kam's Avatar
Kam
Kam is an unknown quantity at this point
My Car Temperature setting is currently stuck on heat. I think I have a bad Temperature door blend actuator. Can someone please help walk me through on how to replace it? Like the location of the actuator etc thanks ! I have a 2003 civic ex sedan
Old Jul 27, 2023
Re: Temperature door blend actuator help 2003 civic
not a general 7th gen car thing, you have a car issue. moving to proper section of forums
Old Jul 27, 2023
Colin42's Avatar
Check that the heater valve in the engine bay isnt stuck
Old Aug 18, 2023
2004LX's Avatar
2004LX is an unknown quantity at this point
I'm having the same problem on my '04 Civic, and in fact had it diagnosed as a blend door actuator. I hope you get an answer cuz i also can't find anything online. I can see the part up above the gas pedal, but not sure how to get to it. But yeah, if you lay on your back on the floor of the driver's side and look up above the gas pedal, you'll see the green plug and the lil white plastic arm. Looks like it's easy to unscrew and replace if I can figure out how to get a screwdriver in there lol
2003civicaz
Exterior
Dec 11, 2022 11:16 AM
gts
Jun 2, 2021 10:00 AM
ericf1993
Aug 20, 2011 11:47 AM
vickifrey636
Aug 23, 2009 09:16 PM
m00ky9
Mar 22, 2009 12:48 AM
