Air Conditioning Post issues with air conditioning here
AC Compressor replacement
Old Sep 7, 2019
payne4200's Avatar
payne4200 is an unknown quantity at this point
The replacement ftom salvage yard
The original one off my car.
I got a 01 Honda civic ex 2 dr 1.7, I took my compressor off to replace it, and bought another one from a salvage yard. The wiring is different from the one that came off my car, the replacement I bought has only 1 wire going to the clutch and the one that came off my car has 2 wires going to the clutch, my question is will it still work?
Old Sep 7, 2019
Slumpertcivic's Avatar
Re: AC Compressor replacement
Should be fine, but definitely energize the clutch before you install it and observe it “snaps” in when powered up.
Old Sep 10, 2019
payne4200's Avatar
bought a new one, but the studs aren't in the new compressor to bolt the ac lines back on to the compressor, was wondering what size bolt I would need to just bolt them back on instead of using the studs and nuts.
Old Sep 12, 2019
BrotatoChip's Avatar
Super Moderator
I believe they are an M6-1.00 bolt. I can get you the size and length when I get home this evening (as long as I don't forget).
Old Sep 13, 2019
Super Moderator
M6-1.00 bolts, something like 25 mm in length should work just fine.
Ggp9909
Jun 5, 2016 09:28 PM
muttleytm
Jul 8, 2015 04:13 PM
hotrod_714
May 17, 2014 04:50 PM
petercivic
Aug 27, 2012 12:15 PM
JoeyCrac
Jun 9, 2009 08:32 AM
