Air Conditioning Post issues with air conditioning here
Ac system PAG OIL
Old Aug 14, 2019
Ryenol's Avatar
Ryenol is an unknown quantity at this point
Ac system PAG OIL
Putting all new AC parts on my 2001 civic. The “kit” comes with a bottle(237ml) of PAG 46 oil. The paper with the compressor says to drain oil that came in compressor out and add proper amount. It doesn’t say what the proper amount is or where to add it. Do I put a little in the compressor (sticker on it said it had 120ml in it) a little in the condensor and so in? PLEASE help
Old Aug 14, 2019
BrotatoChip's Avatar
Super Moderator
Re: Ac system PAG OIL
First off, I've never had to replace the A/C compressor before so my reply is based solely on the information from the service manual. Here is what it says:
So, let's say you drain 80 ml from the old compressor, this would mean you should drain 50 ml from the new compressor before installing (130-80=50). This would leave 70 ml in the compressor if it is filled to 120 ml right now (120-50=70). If you then need to completely replace the oil in it you would drain it and put 70 ml back in.
Old Aug 14, 2019
Ryenol's Avatar
Basically what I did. Thank you very much
Old Aug 14, 2019
Ryenol's Avatar
Old Aug 14, 2019
Slumpertcivic's Avatar
But did you add replacement oil in for each of the other components you replaced?
adamdrives
15
Aug 8, 2015 08:53 PM
velozp
Jul 19, 2013 11:08 PM
Digipixel
1st - 5th Gen Do It Yourself Articles
Apr 1, 2013 12:44 AM
Mackln308
Mar 26, 2011 06:01 AM
Spartanic
Jun 29, 2009 09:54 PM
