A/C works, Heater does not
after being in a small accident the left side of my front bumper had a little dent. I gave my car to a reputable repair shop. They replaced bumper assy and decided to replace a bunch of other stuff to make money of the other guys insurance, like head light assembly, head lights, door handle, repainted the door...etc. All cool...... up until I test my heater and it does not work.
I called these guys explained the situation and they told me to bring it in and they will asses if its an accident related or not. well it is not accident related since it worked fine after the accident.
The engine runs at a normal operating temps, I cheeked the coolant level and it was good, checked the temperature control **** and it moves when I switch between heat and no heat. the only thing that is left is either a bad thermostat or a cloged heater core. how do I test these two? also if my thermostat was at fault wouldn't a/c also not work?
Re: A/C works, Heater does not
Air lock in the core, bad water valve, water valve not opening, HVAC door or mode motor issues, straight undiluted antifreeze, maybe more.
Did the bodyshop have the cooling system open for any reason? Did it get a radiator replaced or something? Did it get the correct antifreeze, and is it the proper concentration?
What's the temp gauge do? Does it show cold all the time?
What temps are the heater hoses at the firewall?
sorry for my late response i was so busy with the work that i completely forgot that I posted here.
lol I spelled the word **** wrong or what?? never knew there is a swear word like that
. the one that is out in the engine compartment.
oh boy this is way over my head, I hope it is just a thermostat. coolant is ok, I used 50/50.
they claim they only replaced radiator bracket, nothing more.
By understanding how they work and observation/testing of temperatures at certain locations.
it's showing normal temps between cold and hot right on the middle.
how do I locate that firewall?
today the heater started working again, I strongly suspect the thermostat is sticking.
thanks for your reply.
****? What ****? You mean the one on the dash that you spin, or the water valve out in the engine compartment?
There's a lot left.
. guess Ill have to wait for that thermostat to come in the mail, will change that and see from there.again thanks for your help, much appreciated.
Thermo is cheap enough, sounds like air. Sticking thermos usually aren't intermittent. Replace the thermo and fill the system up to make sure any air is out. It is commonplace for leaks to rear their head after a collision, don't rule it out.
. Re: A/C works, Heater does not
I replaced thermostat added coolant, purged the system of air and surprise surprise, it still does not work. after running the car for 25min I cheked the two hoses that connect to the firewall and they are cold. also the hose that is connected to the thermostat is cold also.
any ideas?
Go back to posts 1, 2, and 3: What were you calling a "****" in the engine compartment?
The lever on that valve should move a quarter of a turn (90 degrees) going between full cold to full heat.
If it doesn't make the full quarter turn, you need to find out why.
Thanks.
sorry guys, yes its 02 coup lx. I manualy moved that heater controll valve with a long screw driver and whala the heat came back. unfortunately if I turn heat off and put it back on its getting stuck so I have to move it with a screw driver again. Does it mean I have to replace that entire thing or maybe I can lube it or something?
no way in hell I'm replacing that one myself, its in a completely inaccessible place.
You need to figure out WHY the cable isn't moving the lever correctly.
Inspect at both ends of the cable, inspect the outer sheath of the cable for not being anchored in its little clips at either end, heater box linkages, etc.
thanks again.
Can you move it with your fingers ?? May be binding if you need a long screwdriver.
Would that valve try to move during the HVAC system test ???
well now its permanently stuck and I cant manually pry it with a long screw driver, so I'm stuck with no heat
. is there a good guide on how to remove and replace that heater control valve for civic 2002. this valve is located in such a deep @!#hole that the sheer thought of trying to remove it scares the bejesus out of me.
. is there a good guide on how to remove and replace that heater control valve for civic 2002. this valve is located in such a deep @!#hole that the sheer thought of trying to remove it scares the bejesus out of me. If you think a good mechanic is expensive, try hiring a bad one
mikemc422
Aug 9, 2018 05:41 PM
R3KogHyZe
21
Feb 3, 2016 09:23 PM
trellex
May 24, 2015 04:39 PM
ORskier
May 3, 2015 12:54 PM
but i think its called heater control valve. how much does heater controll valve move, mine moves only 1/4 inch.
