Air Conditioning Post issues with air conditioning here
AC Expansion valve location
Old Jul 7, 2009
sparkplug's Avatar
sparkplug is an unknown quantity at this point
Thumbs up AC Expansion valve location
i got a 2004 civic si, i want to replace the ac expansion valve, but wasn't sure where it located in the vehicle. also need some advice when replacing it from experts.
thanks
Old Jun 9, 2019
bbynams's Avatar
bbynams has a spectacular aura aboutbbynams has a spectacular aura aboutbbynams has a spectacular aura about
Re: AC Expansion valve location
It's just a big batch of bolts and screws (8mm, 10mm, Phillips head) but it takes a while. Do you like Legos or crossword puzzles? Glove box, blower motor, blower motor housing (2 pieces or 1... have fun) and a cover. There's a 10mm bolt inside the engine bay; if you pull with about the same amount of force it takes to open a door that sticks, it'll pop. If you'd help someone move and crawl under a sink, it's not a big deal. Otherwise forget it.
Old Jun 10, 2019
Slumpertcivic's Avatar
Don’t see a lot of those being a issue, unless the ac compressor shredded itself to pieces and contaminated the entire ac system with microscopic metal dust.
I hate working under the dash.
Old Jul 10, 2019
M240B's Avatar
M240B is an unknown quantity at this point
I am in the middle of replacing the expansion valve and evaporator. This is after removing the blower unit and ECM/PCM.
pmanftw
General 7th Gen
Sep 25, 2019 12:00 AM
scsmartt
May 2, 2014 08:41 PM
Max91
General 7th Gen
Dec 8, 2012 04:20 PM
smiller521
Jun 8, 2011 07:56 PM
01civicexboy
Mar 20, 2006 10:46 AM
