A/C prob...
You bought a used dog??
A/C prob...
well the main prob is i have no air blowing through my vents. when i turn the **** i can hear the radiator or condensor fan come on and the lil green light comes on but no air. i checked the fuses but didnt see anything unusual. if the fuse was bad i would see burn like marks right?
With the cabin filters out you can see the top of the fan for the blower motor. See if you can turn the fan slightly (with the keys out of ignition)
Looks like fuse #s 1 - 4 -12 in the under hood fuse box. I have wiring info for an 03 if you want it. Let me know if coupe or sedan.
are the blower motor and relays located behind the glovebox?? if its either of those parts hopefully i can find them on ebay or something. i know honda will most likely want to rape me for them.
the blower motor relay is in the under hood fuse box. 4th one to the right from the top. the blower motor assembly is behind the glovebox. make sure the fuse is still good. you physically need to test it. also check the relay. What you can do to check either is swap a good fuse or swap a good relay and see if the motor works.
h4ldol
Apr 24, 2017 08:16 PM
JMKendrick
Sep 16, 2015 06:17 PM
MichaelLW
Sep 14, 2015 07:15 AM
andyandyy
Aug 4, 2015 06:37 PM
