Air Conditioning Post issues with air conditioning here
a/c not as cold as before
Old May 17, 2006
yingjai's Avatar
yingjai is an unknown quantity at this point
not sure if this is the right place to post this thread, but anyway..
my car had this funky smell before and i was told to replace my cabin filters.. yesterday i went out to buy a new pair and popped them in.. now my ac doesn't feel as cold as before..
i used to be able to turn it on slightly and i can feel the cold breeze. never had to turn it on that high cause i wouldnt be able to stand it.. yesterday, i kept turning the fan up cause the a/c just wasnt as cold enough.. almost half way before i can feel it..
is there a break-in period for cabin filters?
Old May 17, 2006
mr_fobster's Avatar
im not sure...but i think you may need to recharge your feron in your ac system...its coming down to summer time and alot of the time if you dont use your ac alot the feron in the system will be discharged.....
Old May 17, 2006
blk04civiclx's Avatar
blk04civiclx is an unknown quantity at this point
is it freon ? or feron? anyways.. I have this problem too.. except my A/c is really moody.. ever since i had my car.. it will blow cold one day and the next day it wont be nearly as cold as it is.. i took it to the dealership and they told me it was blowing at 42 degrees.. =/ i dont think so.. but my car is black so it heats up reallllly fast so that could be a factor...
btw sorry if im thread jacking i was going to put up same thread
Old May 17, 2006
mr_fobster's Avatar
^^ yea sorry about my spelling.......
but i would go t o your dealership and ask em if then can do a ac system diag or inspection. test out the pressure...see if there is any leaks or anything like that.
my aunty had this problem to her 04 maxima...and i took it to my work and just found out that the freon in here ac system has been discharged and just needed to be recharged with some new r134 freon......
this isnt something you can do at home unless you buy the right diag tools(costs about 5 grand for the recharge, vacuum, discharge machine) or if you have your own ac pressure line guages to see if there is a leak in your system or not.
Old May 17, 2006
its r134a not freon
Old May 21, 2006
yingjai's Avatar
interesting.. did i somehow discharge it while i was replacing my cabin filters?
Old May 21, 2006
i doubt it
Old May 22, 2006
yingjai's Avatar
then how come it was perfectly fine before i did the swap?
Old May 23, 2006
civics4everyone's Avatar
civics4everyone is an unknown quantity at this point
did you make sure you installed correctly . Their are arrows on the filters that should flow a certain direction.
Old May 23, 2006
yingjai's Avatar
im quite sure i did.. i carefully pulled the filters out and put them in facing the same way..
Old May 31, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
There are arrows on filter and filter holder.....they should line up...
But the flow should be from bottom to top...Please someone confrim this....
masongardner
Air Conditioning
21
Jun 29, 2019 05:10 PM
andyandyy
Aug 4, 2015 06:37 PM
Jul 14, 2015 03:39 PM
