Engine start problems Post issues with engine start here. Does not start, does not run, etc.
02 civic ex not starting after cold weather
Old Jan 21, 2024
skrrttt's Avatar
skrrttt is an unknown quantity at this point
02 civic ex sedan
after sitting in the freezing Temps overnight the car wouldn't start the next morning. Went to auto zone Checked the battery (bad) and had to get a new one, still doesn't start.
hooked cables up reved the other car while i started mine, i stomped the he11 out the gas pedal and it started. Drove it to auto zone tested the alternator (good). Came home parked it and next day wouldnt start so i took the starter off and tested it (good).
everything checked out fine what else could it be!!!!
Old Jan 21, 2024
Colin42's Avatar
Re: 02 civic ex not starting after cold weather
Bad battery connection most likely
Old Jan 21, 2024
remove, clean ground cables at the chassis
check for damaged wires
Old Jan 22, 2024
BrotatoChip's Avatar
Super Moderator
Or something draining your battery overnight.
LiamHogeterp
Feb 20, 2015 10:36 AM
02 civic ex
Dec 29, 2009 07:50 PM
js89x
Nov 30, 2005 10:43 PM
MangoEX
24
Feb 16, 2003 11:08 PM
beamer
44
Dec 14, 2002 01:10 PM
