Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Clunky start then runs fine
Old Aug 11, 2023
Scott2506's Avatar
Scott2506 is an unknown quantity at this point
I have an 02 civic ex. Had a problem where it would start fine then go into limp mode after a short time running. Threw p1361 or p1362 code and would reset the cycle after clearing the code. Once I replaced the tdc sensor by the cam it fixed the problem but now the engine starts very clunky. When cranked it sounds like something is out of time (maybe?) but makes a clunking noise and runs if you hit it just right. If not it clunks for a second longer and then stalls. Once started it runs fine and has no problems while driving. I also should mention that I did the alternator at the same time as the sensor as the old one was whining. The ac and defrosters don’t work after doing all this so I’m wondering if it might be an electrical problem or maybe these problems aren’t related? I think it could be something with the engine mounts but before I break into that I thought I should check for any ideas.
Old Aug 11, 2023
Re: Clunky start then runs fine
if aftermarket was used change to an OEM sensor. Denso or NTK
honda no like aftermarket sensors (nor alternators)
Old Aug 11, 2023
Scott2506's Avatar
The sensor is but the alternator is not so I might have a junkyard run in the future.
Old Aug 11, 2023
car-part.com is site i use to search scrapyards for parts
unsure if alternator is the cause of the issues you are having, though
Quiznos 713
Jul 20, 2020 11:49 PM
510racer
Mar 1, 2020 10:00 PM
zxzkilme2
26
Jun 15, 2016 11:23 PM
Powder-man
Sep 13, 2012 09:53 PM
ironhide
Jan 8, 2010 03:49 PM
