Engine start problems Post issues with engine start here. Does not start, does not run, etc.
No start no crank issues
Old Jun 18, 2023
Lurkkep3's Avatar
Lurkkep3 is an unknown quantity at this point
Howdy
have a 2004 civic si that is not starting. There has been a whole bunch of different problems and I will explain in order they happened
problem started with a crank/no start. Engine would turn over hard, sounded very healthy. I recently just changed my ignition switch (which gave the same crank/no start problem). But has since been replaced and ran with no issues. Key light is off so I know it’s not the immobilizer.
So I decided to change the fuel pump because I noticed a bit of a misfire recently when initially starting.
Changed the fuel pump with no problems. This is where things got confusing.
Connected battery, tried starting and it fired right up. Ran for maybe 10 seconds, and it shut off. And my alarm started screaming. The horn was going off and the cluster lights were flashing, relays were firing like a war zone. (I didn’t even know my car had an alarm until now, had the car two years and have never heard it)
so looking into this I learnt i have been locked out because the car thought there was a theft attempt.
so I looked into how to get it out of that. Learnt it could be a faulty sensor on the doors. Looked around and driver side pressure switch was pushed into the door. Took it out and put it back, seems to be working just fine.
but I am still locked out of the car. Learnt there are two ways to do this. Radio code and driver door lock. I have an aftermarket stereo and could not figure out the radio code. And my driver side door cylinder was jammed up. (Nothing but problems I know)
So I took it apart and took a few wafers out, turns and locks just fine.
did the key sequence of locking and unlocking 3 times.
this worked and my alarm is no longer screaming, I put my horn fuse back in and that issue has seemed to be fixed.
but now I have a no crank/no start issue. No sounds of any relays or anything, dash turns on, key light goes away, and nothing happens.
Little recap. Crank/no start - alarm sounding/no crank/no start - now alarm is off/no crank/no start
fuel pump has been changed.
replaced main relays.
All fuses checked with test light
battery tested and proven good by auto shop Ignition switch replaced.
Starter was cranking hard with no unusual noises day before new pump was is. Struggling to see how it could be the starter
All new spark plugs and ignition coils in April
All majors connections checked and look fine (battery, alternator, starter, engine/tranny ground)
any help would be greatly appreciated
EDIT: forgot to mention I scanned and got no codes. Or any pending codes. Which is weird because there was an engine light for an o2 sensor before. I’m not sure if it resets when battery is off? And has to run again to throw the code? I heard if it can’t scan at all it’s an ecu problem. Which is the last thing I want
Old Jun 18, 2023
Re: No start no crank issues
if you know who installed alarm, take there. If not, find out manufacturer of alarm and check with them
Old Jun 18, 2023
Colin42's Avatar
If it's an aftermarket alarm remove and restore the wiring to the original configuration
Old Jun 18, 2023
Lurkkep3's Avatar
Sounds good will definitely be the next move. Thanks
Old Jun 20, 2023
Lurkkep3's Avatar
Have just gotten the alarm out. Nothing has changed.
No crank no sounds no nothin. Dash is on, key light is off. Very lost right nkw
any ideas? Thanks
edit: while I was breaking my back getting the alarm out figured I would look at the clutch switch. Looks completely fine, came out all the way, bumper still there.
Old Jun 20, 2023
Colin42's Avatar
Tested the starter?
Old Jun 20, 2023
Lurkkep3's Avatar
Not tested, but it was cranking hard till it killed my battery the first day.
Day after I did the fuel pump and after charging the battery this happened.
so I’m struggling to see how it could be the starter?
Old Jun 20, 2023
grounds good?
connections to the starter motor good?
Old Jun 20, 2023
Lurkkep3's Avatar
All grounds checked
Old Jun 20, 2023
test wring with multimeter?
Old Jun 20, 2023
Lurkkep3's Avatar
What am I looking for? Will it be battery voltage?
Old Jun 21, 2023
no, if you are getting power at the starter, for example
Old Jun 21, 2023
Colin42's Avatar
You might have burned it out if you were cranking it for a while.
wwhitby
Jan 28, 2022 05:38 AM
RedNoBread
Jan 29, 2021 12:05 AM
Ted-04
Feb 5, 2019 01:52 PM
wpendl1
May 1, 2017 04:14 PM
mwrohde
Mar 24, 2017 07:56 AM
