Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Cranium
Old Dec 27, 2022
Cranium1814's Avatar
Cranium1814 is an unknown quantity at this point
Cranium
Hey there , this thread is for Canadian civic owners and its a real puzzle . I recently replaced the engine in my 03 civic si and everything went great on the install until I tried to start the car . After connecting the battery I attempted to start the engine , it turned over great but wouldnt fire so I proceeded to check for spark and fuel . After confirming I had both I attempted to again to start the car but had no success as it would turn over but not fire . Now comes the strange part , thinking I might have a bad sensor or some other issue I connected a basic OBD reader and surprisingly the car fired right up however my speedo was behaving as a tach and was moving according to RPM change I shut the car down and started checking all my harness connections but found nothing . I then got back in the car and started it again however when I reached down and unplugged the reader the car stalled and would not refire but as soon as I plugged the reader back in the car fired right up the speedo was still bouncing around like crazy . Has anyone out ever had this happen to them before or does anyone have a suggestion or 2 as to what I might look at to fix this problem any help would be greatly appreciated
Old Dec 27, 2022
Colin42's Avatar
Re: Cranium
You're missing a ground connection, probably on the water neck, check all of them carefully though.
Techie
Jan 18, 2021 09:11 AM
Twisties
Mar 7, 2019 10:27 AM
txaicivic
Nov 7, 2012 08:42 PM
saadriaz
Jun 27, 2010 07:46 AM
vallumlj
Nov 23, 2007 03:41 PM
