Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2003 civic problem HELP PLEASE
Old Feb 26, 2022
Taurusx71's Avatar
Taurusx71 is an unknown quantity at this point
Hey everyone hope all is well. I am hoping someone might be able to help me with this problem. My grandson has a 2003 civic I believe there is around 205k on it we baught it a few months ago before he got his license and he is now a licensed driver. Just wanted to tell this because this is the reason we really don't know the history of the car or anything that has been done to it so can't answer any questions about it's past. That being said. Here is what we have done. Engine light was on for Crank shaft sensor so we replaced that and now engine light is not coming on anymore and we have scanned it a few times since just to check for pending codes and nothing. Installed new fuel pump car seemed to have better power and runs great down the road. This is the VTech engine. The problem we can't figure out is that there are times it starts right up and then it drives and it could be just a couple miles and after it's shut down it will crank but not start. Then sit for a little while and then restart. Sometimes in the morning go to Start and it won't then go back out a few minutes later and it starts. This happens at all times of the day so not a cold start issue. Like I said no engine light on so it's frustrating trying to figure it out. Any help is appreciated.
Old Feb 26, 2022
Re: 2003 civic problem HELP PLEASE
hondas don't like aftermarket sensors.
the crank shaft sensor, was it OEM?
Old Feb 26, 2022
Taurusx71's Avatar
It was purchased at O'Riley auto parts so I would guess it's not OEM. So the sensor would make the engine light stay off but not work correctly ?
Old Feb 26, 2022
could, yes
denso is the oem
Old Feb 26, 2022
Taurusx71's Avatar
Ok it's worth a try. I will buy an OEM and see what happens. Thanks
Old Mar 6, 2022
Taurusx71's Avatar
Ok everyone I tried installing new OEM sensor and still having problems. I am fairly certain it's not fuel related. I had it cranking and put a little spray to it and still not starting. Then after a few minutes sitting it started. Then turned it off and it wouldn't start again. Also it's having problems with not idling when at stop sign or in drive thru it will die
Old Mar 6, 2022
Colin42's Avatar
Verified timing yet?
Old Mar 6, 2022
Taurusx71's Avatar
Yes and belt is good. Just disconnected battery for about 10 minutes and it's been starting. But who knows for how long. When it's running it runs great
Old Mar 15, 2022
basscat2017's Avatar
basscat2017 is an unknown quantity at this point
My 2004 has a similar issue, but if I barely give it a little gas pedal while cranking it fires right up.
jazzadellic
Oct 20, 2014 11:09 PM
Jtb93
Apr 12, 2014 10:26 AM
smihz
Oct 2, 2011 10:19 AM
saadriaz
Jun 27, 2010 07:46 AM
fahadlovely
Oct 11, 2007 08:32 AM
