Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2004 Civic LX will not start unless pressing gas [solved]
Old Feb 12, 2023
  #31
Dj fuze's Avatar
Dj fuze is an unknown quantity at this point
re: 2004 Civic LX will not start unless pressing gas [solved]
Originally Posted by Lennon Fay
A month or two ago my civic would sometimes die when reversing after a cold start and now it will not start unless I press my foot on the gas pedal while trying to start it (this can be a lengthy process that takes a couple of attempts). It also has a rough idle and I will have to hold my foot on the gas pedal to make sure that it doesn't dip below 1k RPM and die (usually have to do this for 20-45 seconds). Fuel economy has also been bad. Does this seem like a spark plug issue? I am not very car inclined.
2004 Civic LX
164,000 miles
Clean the throttle body
Old Feb 13, 2023
  #32
Fry's Avatar
Fry
Fry is an unknown quantity at this point
Re: 2004 Civic LX will not start unless pressing gas
DJ Fuze, Thank you. I did clean the throttle body the first thing I did. I checked my fuel injectors, and put heet in the tank in case I had some bad gas. I suspected the head gasket a couple weeks in advance, but I guess I was in denial. The cost of antifreeze is so high, I think I spent more on antifreeze than getting the head milled! Great videos on you tube on how to take the head off, I have done it twice now in the last 2 months!
Giberish33
Feb 16, 2021 06:25 AM
Gallegos1982
16
Apr 3, 2020 12:59 AM
ASchwagman
Oct 22, 2018 11:22 AM
Rushifier
Mar 11, 2017 10:51 PM
Redneck757
Apr 24, 2016 12:14 PM
