Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Cranks but wont start
Old Mar 21, 2021
Bobo6's Avatar
Bobo6 is an unknown quantity at this point
So my car has been idle for 2 years. When i turn the ignition i dont hear the fuel pump prime the engine turns over but wont start. I checked fuel pump and found a rats nest also check the computer for problems and none come up. Im not sure if the computer would detect a messed up wire or not but does anyone have any ideas? Please help
Old Mar 21, 2021
Wankenstein's Avatar
Re: Cranks but wont start
Post pics please. Most likely a break in the fuel pump wiring.
With some vehicles (manufacturers) the fuel pump can be directly tested with a 9v battery and alligator clips after disconnecting the harness connection at the pump itself. I haven't tried that on the Civics I've owned though because they never had a fuel pump issue.
Old Mar 21, 2021
Bobo6's Avatar
Allright ill post some pics in the morning and try what you said
Old Mar 22, 2021
BrotatoChip's Avatar
Super Moderator
When you try to start does a green key symbol flash in the cluster?
Old Mar 23, 2021
Bobo6's Avatar
This is the fuel pump
So this is in the engine bay online it shows a box below it but its not there i guess it wasnt a civic si
This is under the dash
Thats behind the glove box online says there are sensors and stuff for the fuel pump injectors ect i dont see it is it behind the metal casing?
The dash lights after i disconnected the fuel pump when hooked up yellow light by fuel guage isnt there
Old Mar 23, 2021
Bobo6's Avatar
Yeah there is a green key when i turn it on but goes off pretty fast. Then i tested at the plug after disconnecting the plug no power on the plug is it possible that its one of the sensors?
Old Mar 24, 2021
Super Moderator
That's good, it means the immobilizer is not preventing the fuel pump from running. Should be a fuel pump fuse in the under-dash fuse box, check it. You can also measure voltage in the fuel pump connector (during the initial two second prime or while cranking), you should see battery voltage across the yellow/green and black wires.
jimmycrackorn28
Feb 12, 2020 08:25 PM
naphz
Oct 12, 2019 01:14 PM
heydude111100
Nov 16, 2011 07:24 PM
gotti
Engine Swaps
Jul 11, 2004 05:23 AM
