Engine start problems Post issues with engine start here. Does not start, does not run, etc.
P0336 code
Old Jun 13, 2020
JND0816's Avatar
JND0816 is an unknown quantity at this point
P0336 code
My '03 1.7 V-tech Civic died on me during a down pour. Towed to the house and found my crank position sensor and wire connector were bad. I exchanged both but still get a p0336 , cranks and idles but but won't exceed 3500 RPMs. Don't know where to go from here. I'm just a DIY guy so does anyone have any advice? Thanks in advance!
Old Jun 13, 2020
FRSam's Avatar
Click Here
Re: P0336 code
My first guess would be to check timing. Sounds like your belt skipped teeth. You’re lucky that it’s still running.
Old Jun 13, 2020
JND0816's Avatar
Re: P0336 code
Will give that shot and let you know. Thanks
Old Jun 13, 2020
FRSam's Avatar
Click Here
Re: P0336 code
Totally read that as cam position. Disregard what I said.
It sounds like you’re in limp mode. If I’m not mistaken, low oil levels on the vtec engines cause limp mode to engage. That’s an easy first place to check.
Old Jun 13, 2020
JND0816's Avatar
Re: P0336 code
Just looking over videos on timing check...LOL. Are there any other causes of the limp mode?
Old Jun 13, 2020
Colin42's Avatar
Re: P0336 code
Did you put a non OEM sensor in?
Old Jun 13, 2020
JND0816's Avatar
Re: P0336 code
Yes, purchased from Autozone
Old Jun 14, 2020
Colin42's Avatar
Re: P0336 code
Fail, go buy the proper sensor from the dealer
ajpats26
Electrical
Apr 22, 2019 06:02 PM
drzvfr
Oct 14, 2018 12:11 PM
carlosdee
Sep 12, 2014 10:48 PM
got2run5
Feb 2, 2012 10:30 PM
IRPancake
Oct 8, 2009 12:21 PM
