Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Engine wont start
Old Jul 18, 2019
hondategridy's Avatar
hondategridy is an unknown quantity at this point
Question Engine wont start
So i recently installed a new engine in my 04 1.7l civic and i got everything reattached like its suppose to and it wont start
Ik its rolling over,
im getting fuel and im getting spark i have a brand new battery. No codes are showing up on my ob2 scanner
Any suggestions about what might be causing my car not to start. Seriously stumped atm
Old Jul 18, 2019
Colin42's Avatar
Re: Engine wont start
got compression?
Old Jul 18, 2019
Its got compression on all 4 cylindeez hitting at 9.5 kgs like it should
Old Jul 18, 2019
Update i took the top o2 sensor out and it started right up with no problems
Old Jul 18, 2019
Colin42's Avatar
Exhaust restriction then?
Old Jul 18, 2019
Yeah i think my cat is bad from where the old engine ****ed it up
Old Jul 18, 2019
Colin42's Avatar
Well at least it should be a straight forward fix then
Old Jul 18, 2019
Wankenstein's Avatar
Try starting it with gas pedal pushed to the floor..this disables the injectors and allows maximum air into the cylinders. Seems counterintuitive but it worked for me after head gasket replacement and other times when the engine wasn't cranked for a couple weeks. If that doesn't work spray starter spray in to the TV and crank the engine
Old Jul 19, 2019
Firat thing that i tried lol but i took my cat out and it rattled like some maracas
Old Jul 19, 2019
Colin42's Avatar
check the rest of your exhaust for chunks of cat
Old Jul 19, 2019
mac25's Avatar
Dr Krieger of Modification
RiP Mr.Mittens... lol
Old Jul 19, 2019
Colin42's Avatar
Old Jul 19, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Bet you wanted to shuffle your feet when you shook your cat.
Lakejay
Jun 25, 2016 10:23 AM
Dolphin Sashimi
Dec 12, 2012 11:06 PM
VicSlick
Oct 27, 2011 02:07 PM
TheHumanV
Jan 4, 2003 12:53 AM
