Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Replaced Fuel Pump - Won't start
Old Jul 1, 2018
Redhead818's Avatar
Redhead818 is an unknown quantity at this point
Greetings,
My 2002 Civic LX wasn't starting very well. So....I changed out the Fuel pump, and Fuel Filter. Now it won't start at all. I took the fuel pump assembly to a local shop, and they tested the pump with 12V's. The pump works. I checked the Fuse that is associated to the fuel pump. Does anyone have suggestions on what to do next?
Thank you for any help that you can provide!
Kevin
Old Jul 1, 2018
Slumpertcivic's Avatar
Re: Replaced Fuel Pump - Won't start
Fuel pump issues usually present as no fuel or loss of power under acceleration due to low pressure.
If you car is not throwing any codes, I would check the timing belt to make sure you didn’t skip a tooth or two.
If you didn’t buy a actual Honda fuel pump, you should reinstall the original one and see if it starts works as before.
crazyone64
General
Apr 16, 2019 12:52 PM
Jorge Alcoce
Aug 30, 2017 10:08 PM
amberlynette
Apr 2, 2010 12:38 PM
brianturbocivic
May 4, 2005 11:07 PM
cosmo
Aug 11, 2004 05:00 PM
