Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Car Won't Start on Hot Days or after making other stops
Old Apr 28, 2016
99FeatherStar's Avatar
99FeatherStar is an unknown quantity at this point
I have had this problem with the car since I got it six years back, but it won't start if it is a hot day (especially a dry day) or after I have made several stops for the day (For example I go to three places in a couple of hours, by the third place, it doesn't want to start). I have taken it in, they have replaced the alternator, starter, battery cables and the battery, and the problem still went on. I even had one mechanic say it was probably because the starter they just put in was defective, so the replaced it with a new one and it still did the same thing.
The car will start eventually, I just have to wait a few minutes. It sounds like it is trying to "catch" to start, it will make the same noise along with a faint clicking sound. It seems like when I turn the key to turn on the car, but not start it, and leave it for awhile, it helps.
Because the car starts eventually, the mechanics that I have been too, one of them who I have been going to for years and specializes in Hondas, says they can't find it, it could be a ground wire issue. And that it will cost me a bunch of money to trouble shoot.
Before I do that I wanted to post on here to see what others might think it is, I have searched similar forums and it sounds like it could be a main relay, but who knows.
I have attached a video of what it does, it will do this for a couple or several minutes, then it will start just fine.
It's a 2005 Civic SI, has about 140k miles.
Thank you for reading and thanks for your help!
File Type: mov
Last edited by 99FeatherStar; Apr 28, 2016 at 11:20 AM. Reason: To include model/year
Old Apr 28, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Car Won't Start on Hot Days or after making other stops
I have read that a failing main fuel relay can cause your symptoms in hot weather. I'd seriously look into swapping that out to see if that helps. I know you have thrown a lot of part s at it but if it were me I would try this one last solution.
Old Apr 28, 2016
Colin42's Avatar
Fuel pump/filter? Air filter?
Old Apr 28, 2016
In your video I hear a short buzz followed by the sound of the starter cranking normally then the engine starting.
The short buzz is usually repeatable on many of Hondas cars whenever the key wasn't twisted all the way to crank position, or it was twisted too slowly.
Old Apr 29, 2016
NDNV's Avatar
Another check would be failing electrical contacts in the ignition switch.
Old Apr 29, 2016
Thank you for your input! I will check all of these things out!
Old Jul 18, 2019
texans's Avatar
texans is an unknown quantity at this point
Were you able to diagnose the issue. I'm having something similar.
Old Jul 18, 2019
this is a 7th gen, different animals
Old Jul 19, 2019
texans's Avatar
Thanks. Yeah different generation for sure.
Old Oct 12, 2019
Wistech100215's Avatar
Wistech100215 is an unknown quantity at this point
I just got done repairing my 2005 honda civic ex special edition, the crankshaft speed sensor plug got salt water damaged or corroded it would randomly not start after short trips to like 5 to 10 miles, never had a service light or code for the no start problem, I found it by watching live feed of the engine rpms with this problem the rpms were very erratic or none at all causing a no start until it colded for 30min to sometimes 12hrs before it would start again it took about 3 months to figure this out because it completely failed yesterday then today I was going to replace both the crankshaft sensor and cam sensor when I found the bad plug and replaced it with a like new used plug cut off of a 2003 Honda civic hybrid map sensor my spare car for parts.
Old Jan 2, 2020
Note if your 1.7l 7th gen civic randomly don't start but turns over fine make sure the crankshaft sensor is sending a good signal to the ECM because my 2005 ex civic needed a new crankshaft sensor and wiring harness plug installed to fix the problem, my car started this problem at about 144,000 miles I repaired it at 160,000 now has almost 180,000 miles on it never had a starting problem since, good luck everyone
Cecilep
Apr 9, 2018 04:45 PM
thatboi901
Jun 15, 2011 10:48 AM
kbook
Apr 8, 2011 11:35 PM
mc670
Feb 5, 2011 08:20 AM
XBRMann
Nov 6, 2009 11:33 PM
