Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
2001 ex transmission problem
Old May 3, 2024
crabbydad's Avatar
crabbydad is an unknown quantity at this point
I was driving my 2001 civic ex automatic the other day and out of nowhere it revved up(transmission slipped). I continued on to where i was going with no issues. When I got home I checked the fluid and the level was ok and the fluid seemed ok, not burned. The next day i started it up and drove up and down our long driveway a few times. It was slipping and slow going in to gear. I left it running and checked the fluid again and looked around to see if any sensor wires were unplugged. when I got back in, it would not go into any gear, so I pushed it back to its spot. The next day I came out and started it and it went into gear and would move, nut transmission was whining fairly loud. No check engine lights on the dash.
Any thoughts?
Old May 3, 2024
Colin42's Avatar
Re: 2001 ex transmission problem
Trans is known to be the weak point on the 01-02. Get a trans from an 04-05
Old May 4, 2024
FRSam's Avatar
Click Here
If P0730 isn’t showing, I’m betting it’s stored. Put a code reader on it anyway.
Old May 4, 2024
crabbydad's Avatar
I checked and there were no codes
I picked up a transmission from a guy who said it had been rebuilt with a little less than 14,000 miles on the rebuild and the car was rear ended, so he pulled the trans before scrapping the car. I started on pulling the transmission today. Lots of metal on drain plug and fluid was dark, so I think it was done, especially with knowing the history with this year transmission. 199,000 miles on the car. Contemplating swapping the engine out with a JDM while I have the transmission out. It burns oil and there is a leak that looks like its coming from the head gasket.
Old May 4, 2024
burning oil and headgasket are two other common issues in this car.
Oil is from carbon deposits sticking to the oil rings and collapsing them.
Headgasket is expected to fail every 100k miles or so.
Old May 6, 2024
BrotatoChip's Avatar
Super Moderator
I've never seen a head gasket leak oil externally. You should look at other locations for the source.
Old May 6, 2024
crabbydad's Avatar
Now that I have the transmission out, I can get a better look to see where it is leaking. Possibly back side of valve cover. I would like to fix this, the leak made a mess of the transmission. Replacement transmission doesn't have the locating dowels in it and hard to get the old ones out without deforming them a little , so I am going to make new ones. (I'm a machinist)
Old May 6, 2024
Super Moderator
There is also a plastic plug for the end of the camshaft that is a known oil leak spot. Only other common leak would be VTEC solenoid (if it's not the valve cover gasket).
Old May 6, 2024
crabbydad's Avatar
thanks a lot, appreciate it, I will check those out.
Old May 7, 2024
crabbydad's Avatar
a lot of oil around the solenoid and the camshaft plug, so I'm replacing the solenoid gaskets and cam plug. Good call BrotatoChip, Thanks!
Old May 7, 2024
Super Moderator
Might as well do the valve cover gasket as well!
Old Dec 8, 2024
kurtbarlow's Avatar
kurtbarlow is an unknown quantity at this point
Any thoughts?
what DTC codes are coming up??
Old Dec 8, 2024
crabbydad's Avatar
I didn't get any codes, I ended up swapping the trans
Old Dec 8, 2024
kurtbarlow's Avatar
Great, what trans model did you install?
emich
Transmission
Oct 17, 2023 07:45 AM
adtillery21
Transmission
22
Apr 23, 2020 01:33 AM
ray13
Transmission
Jan 19, 2016 06:07 PM
Strangerjle
Mar 23, 2012 04:14 PM
Gummiesaver
Feb 28, 2011 06:52 PM
