Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
Transmission problems?
Old Mar 9, 2009
POQbum's Avatar
POQbum can only hope to improve
I'm not sure if it's always been like this or if I just started noticing- but every time I accelerate and it shifts from a lower to higher gear, I get a sort of pause..or surge when it switches gears (automatic transmission).
Is this normal..?
Old Mar 26, 2009
Geoo's Avatar
Geoo is an unknown quantity at this point
Re: Transmission problems?
that happend to me yesterday, i hate to say it bu it sounds like your transmission is about to give out on you because mine did now my car wont move
Old Mar 26, 2009
you mean its slipping gears? like when it should be shifting, the engine revs up like its in neutral? if thats the case then ya get ready for a fail while driving one day.
Old Mar 28, 2009
POQbum's Avatar
Any suggestions?
Should I try to repair it, or just get a brand new one?
And do you know of any good places to buy a good cheap tranny?
Thanks.
- Paul
Old Mar 28, 2009
Geoo's Avatar
you will need to buy a new one i say you see if anyone you know knows someone who can do it because auto shops are way over priced, my uncle knows someone and hes only doing it for 1000 cmpared to 3500 at the shop
Old Mar 28, 2009
well for now keep driving til it breaks. you may get some more use out of it. until it starts slipping 1k rpm and more, id say you still have time.
Old Mar 31, 2009
POQbum's Avatar
Sorry to drag this thread on, but I'm a little confused and hoping to get some more advise or suggestions.
So ok, since it seemed my transmission was slipping and it shifted hard I decided to take it into the dealer to see what they had to say about it. They checked it out, 'test drove' it twice, 1st time 15 minute session, second time 30 minute session and they said it was all ok, no problems. They said if there was a real problem, like the transmission slipping, then a computer chip on the car would tell them that problem and it didn't.
I get it back and it drives great for 20 minutes, then it starts shifting really hard from 1st to 2nd and 2nd to 3rd - I feel it surge forward every gear change.
My car only has 37,000 miles on it and I don't drive recklessly (most of the time ), and I'm easy on the transmission - so this issue is really bugging me to death!
Do you think this still sounds like a transmission issue? Maybe something else could be loose .. or not well lubricated.. ?
Also.. I got the car at 12,000 miles and it was perfect, the guy maintained it very well. The only thing I've done since then is an oil change and tire rotation + balance. Should there be some other routine maintenance that should be done?
Please any input would be awesome.
Thanks guys.
- Paul
Old Mar 31, 2009
yes its a defect, not your fault. nothing you can do other than rebuild the entire trans. ive seen some of them fail at 20k miles and others at 100k miles. all you can do is change the fluid it may shift smoother but the slipping wont go away.
Old Apr 1, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
what with all the auto tranny problems? Mines got 60K miles on it and i rip on it occasionally (100+mph) and its not slipping at all. Mines a 2002 btw
Old Apr 1, 2009
POQbum's Avatar
Originally Posted by wallydude03
Mines a 2002 btw
Huh? You mean you put a 2002 btw tranny in your honda civic.. ? Or do you drive a 2002 bmw?
This is a Honda civic forum
Old Apr 1, 2009
btw = By The Way
Old Apr 1, 2009
POQbum's Avatar
Oh..I'mm dumb. Something in my head made me think that said bmw and not btw...
Gah.
Anyways I think I'm on the verge of spamming this thread. I guess I'll just wait it out and see if the problem gets any worse, maybe get it checked by a transmission shop instead of the dealer next time.
Thanks for all the help-
MajTom
Jun 2, 2015 11:48 AM
Schneiderman
May 24, 2015 01:14 PM
cruisers10
May 12, 2015 10:46 PM
Jessica Leung
May 5, 2015 05:12 PM
markp94
Apr 30, 2015 09:19 PM
