Rear wheel negative camber
Old Oct 17, 2021
Achrisb1's Avatar
Achrisb1 is an unknown quantity at this point
I'm new to working on suspension. I just replaced all four struts before noticing my left rear wheel is noticeable crooked. At a negative camber. My trailing arm bushings are bad, but would that cause this or is there something else going on? Is the trailing arm bent or is it just out of alignment? Any info appreciated.
Old Oct 18, 2021
Re: Rear wheel negative camber
yes. fix it and take to alignment
Old Oct 18, 2021
Achrisb1's Avatar
Thanks, just didn't want to change those pain in the butt bushings and still see it crooked. I can't see them very well, but they both look to be torn just as much. The right side looks relatively straight though which is why I was worried that it was something else. Now that I think about it the car was leaning to the left with the bad struts for a long time so maybe that helped it get like this.
tn_neon
Jan 13, 2019 07:12 PM
97EKHatch
Mar 7, 2014 07:11 PM
kinakoes2
Feb 27, 2014 08:32 PM
klectic
Feb 23, 2006 01:28 AM
shifthis
May 14, 2005 06:01 PM
