Fuel door won't open 1997 hatchback
Old Nov 13, 2023
Jeff79's Avatar
Jeff79 is an unknown quantity at this point
My 1997 haatchback has a problem with the fuel door. The lever isn't releasing the door. I checked the cable and it is still attached up by the driver's side. I saw in another forum that the cable connector at the fuel door can be turned 90 degrees to take out. But I can hardly get my hand around it, much less turn it. Any tips for how to get it out so I can at least open the fuel door? TIA
Old Nov 14, 2023
Colin42's Avatar
Re: Fuel door won't open 1997 hatchback
Use pliers if you cant get your hand in there
Old Nov 14, 2023
Jeff79's Avatar
Thanks, Colin42! I did try pliers but it was just too tight a space. I was finally able to get it to turn and pop out, releasing the fuel door. I checked the cable which is working properly. The actual problem seems to be the latch on the door itself. I bent it back a bit to see if that worked, heard the metal crunch like it was going to break off. So I stopped. I'm not sure what the latch is supposed to look like normally; it looked a bit twisted to me. So I will have to mess with it some more when I have time.
Old Nov 14, 2023
car-part.com for nearby scrapyards, pull one out of a car
Old Nov 14, 2023
Colin42's Avatar
Post some photos of the door if you want
Dlively
Exterior
Oct 27, 2020 10:39 AM
nk24
Dec 4, 2017 11:47 AM
qfinger
Buy, Sell, & Trade - Archive
Nov 21, 2007 02:04 PM
dxcivic2002
Mar 5, 2003 02:13 AM
skier167
Exterior
Jan 29, 2002 08:24 AM
