Honda civic ek hatch radiator fan issue
Old Dec 12, 2023
Tonyrips's Avatar
Tonyrips is an unknown quantity at this point
NVM problem fixed, power wire was toasted in the connector
This car is manual swapped. The radiator is currently wired to turn on with the ignition. So it works
I connected the stock plug for the radiator and tried jumping the coolant temp sensor to see if the fan would turn on but i can just hear the relay click. I checked to see if there was voltage flowing through the power cable and there is, but there seems to be 0 flowing through the ground when the sensor is jumped.
I checked the ground and it appeared the be fine, i switched the ground point and still nothing. Condenser fan also doesnt turn on but ac works if that makes a difference.
Could it be that the relay isnt sending the signal to ground the wire? im lost any help is appreciated. Id love for the fan to turn on with the coolant temp sensor if not i will just wire ln a switch
beegyboy22
May 26, 2017 06:29 PM
chris81326
Nov 9, 2015 08:39 PM
hokiedad4
May 3, 2015 10:06 PM
Tinkerbell_too
Dec 24, 2010 12:48 PM
supafreak101
Sep 4, 2005 08:02 PM
