Problems after replacing oil pan
Old Aug 1, 2023
andis28's Avatar
andis28 is an unknown quantity at this point
Hey, I have a 98 civic EX and had a pretty bad engine oil leak. I replaced the oil pan which involved me taking off the exhaust manifold to get access to the pan screws. My exhaust harness behind the catalytic converter was broken so when I removed the manifold the cat dropped about a foot and the o2 sensor there snapped free from the harness. I thought I could just tape it since it looked like only the clip was broken. I put everything back together and car started up fine, but I have a check engine light and when I went to read it my obd sensor no longer connects to the port? I tested the sensor itself in another vehicle and it works fine it doesn’t recognize my car. What could I have done to it that would cause my obd sensor to fail at the exact time my oil pan was changed? I am pretty sure the secondary 02 sensor must have broken a pin when it fell so that would explain the CEL, but not reading the obd scanner is odd, I replaced the fuse thatis connected to it but nothing changed. Any tips?
Old Aug 1, 2023
Colin42's Avatar
Re: Problems after replacing oil pan
Sure you got the right fuse?
Alex Whiston
Aug 17, 2020 06:18 AM
butterblum
Nov 8, 2016 08:14 AM
TS2008
May 14, 2016 03:00 PM
Speedracer32
Engine Swaps
Jun 16, 2004 11:23 AM
BlackIce
Aug 4, 2003 06:27 PM
