Heating problem D16Y8
Old May 10, 2023
angeloisdead's Avatar
angeloisdead is an unknown quantity at this point
I have changed almost everything in the cooling system except the fan. Ik it works bc it turns after a good good while is that normal? The reservoir always fills up boiling after a 30 min drive or after the freeway. Anybody know what it could be?
Old May 10, 2023
Colin42's Avatar
Re: Heating problem D16Y8
Headgasket is blown or coolant is low. Or headgasket is now blown from the coolant being low
Old May 10, 2023
Fr? I don’t have any other symptoms of a blown gasket. I should see how the oil looks huh?
Old May 10, 2023
Colin42's Avatar
That is the only symptom these engines show. They don't do the milkshake
Old May 10, 2023
the reservoir filling up is all the evidence needed.
you can also do this test
We saw many people in denial, but they all ended up changing the head gasket. (yes, it is common, so common that we created this thread
https://www.civicforums.com/forums/3...reference.html
Old May 15, 2023
Hey if that’s the case do you guys have any video on how to change it? Or what I do next.
Old May 15, 2023
it is a lot of work, more than a video can take
Old May 16, 2023
Dang around how much would it run me?
Old May 16, 2023
no videos, but here is one narrating his experience on a 7th generation - yours is 6th so some differences in engine configuration, parts
typically full time two days work, so expensive
https://www.civicforums.com/forums/3...placement.html
I did at home, at my leisure - two months to finish
Old May 16, 2023
Colin42's Avatar
Check youtube. Either you fix the engine you have or dump another engine in it
Ek_Juan12
Jan 7, 2014 03:14 PM
J1980jr
Jul 31, 2013 02:47 PM
civicboi17
Feb 12, 2011 03:34 PM
EKCivicDreams
Jan 9, 2011 12:13 PM
