D16y7 distributor on d16y8 motor
Old May 14, 2022
Jdm6969's Avatar
Jdm6969 is an unknown quantity at this point
I’ve been reading forums with both responses of yes it will work and no it will not work so I’m just trying to figure it out if I need anything extra for it to work or is it just plug n play when I change the distributor.
Old May 14, 2022
FRSam's Avatar
Click Here
Re: D16y7 distributor on d16y8 motor
I don’t think they’ll work. I have a friend currently swapping a Y8 head onto his Y7 and the mounting points are different.
Old May 14, 2022
Colin42's Avatar
Just put the proper one on
Old May 16, 2022
Jdm6969's Avatar
I changed the distributor and it wouldn’t start after could it be something with the timing or the distributor came out defective?
Old May 16, 2022
FRSam's Avatar
Click Here
Did you time the distributor?
Old May 16, 2022
Jdm6969's Avatar
Yes I timed it and made sure it was the same angle as it was before…
Old May 17, 2022
Jdm6969's Avatar
I ordered a TD73u distributor online and I’m hoping that’ll start the car right up. I’ll update this post if I face anymore issues!
Old May 17, 2022
FRSam's Avatar
Click Here
Please update if it works as well. No point in leaving it on a cliffhanger.
Old May 25, 2022
Jdm6969's Avatar
I changed the distributor but while trying to cut it on I didn’t notice that a bolt of the starter was messed up. So each time I tried cutting it on it was messing up the starter overall and it broke. So I went to get a starter the next day and I put it on. Now the car just cranks doesn’t start idk if I have to change the spark plugs because they are bad or if it’s something else, at this point it’s looking like a lost cause… any help is appreciated..
Old May 25, 2022
Colin42's Avatar
Does it have spark?
Old May 25, 2022
Jdm6969's Avatar
Originally Posted by Colin42
Does it have spark?
How do you check if it has spark?
Old May 25, 2022
Colin42's Avatar
There's probably a hundred different videos on YouTube
omarz13
Mar 24, 2020 07:10 PM
tattedlariat
Dec 31, 2015 10:57 PM
civicwad
Dec 31, 2010 09:43 AM
smokiemcpot
Aug 30, 2009 10:35 AM
camarossguy2
Jun 22, 2008 03:56 PM
