Engine compatability?
Old Mar 11, 2022
mustang rich's Avatar
From: I reside in South Douglas county oregon.ask someone they will know where to find me
mustang rich is an unknown quantity at this point
hello this is mustang rich new member.im seeking advice and info on engine compatability.i have a 98civic with d16y8 and want to know if a 2001 civic engine will interchange and all of the details involved if its possible. The 2001 has manual trans.i havent got an engine code yet for 2001. All i have is a photo of engine.can purchase donor car for $400 if i can use the engine in my 98 civic.will someone be kind enuff to walk me thru this before i buy the car to find out it wont work.i thank you for your time ,trouble and support.thank u much
Old Mar 11, 2022
BrotatoChip's Avatar
Super Moderator
Re: Engine compatability?
The 2001 is a 7th gen (D17a1/D17a2), you have a 6th gen. Different engines. I'm sure it could be done but it's much more in-depth than just swapping parts.
Old Mar 11, 2022
7th gen don't have distributor, so you will need the new ECU.
But ECU needs the key programmed (anti-theft) and the ignition that reads the key.
all the other sensors - i think they might be different.
Old Mar 11, 2022
Thank you for the reply and the info.i had no idea the complexity of a honda interchange.this is why i came here.i seen a chance to possibly save money buying. The2001 for $400 rather than $1350 for used engine from japan.do i have any other options ? If u would be kind enuff to point me in the best direction im all ears.thank u much for your trouble
Old Mar 11, 2022
question - is the 2001 a EX or other?
Old Mar 11, 2022
Colin42's Avatar
Don't bother trying to put the wrong engine in.
look for 98-00 they should drop right in. 96-97 will also work but some things may need to be changed
mike96gtvert
23
Mar 17, 2022 11:32 AM
Taurousan
Engine Swaps
Dec 27, 2013 04:59 AM
Cree01
Jul 19, 2003 03:47 PM
neocivic
Oct 20, 2002 03:22 PM
Jr
Dec 1, 2001 09:20 PM
